Ingalls Problem
Old Oct 13, 2007 | 10:36 AM
godsfshrmn's Avatar
Ingalls Problem
Is anyone else's Ingalls making a squeaking noise when you are kinda harsh on it? I really notice when I am moving and go back into first gear (which usually isn't smooth) and it makes this horrible metal:metal noise. The gasket was between the damper and the brace as the instructions say. It worked just fine the first time I put it on. Then I took it off to tighten it up because I was still getting wheel hop and then this started.
Old Oct 13, 2007 | 10:49 AM
blackngold20's Avatar
never had that problem...you check the aligment of the dampner and make sure its straight?
Old Oct 13, 2007 | 02:47 PM
godsfshrmn's Avatar
Yeah the fit is perfectly straight. Its like the damper itself compresses whenever it gets under stress, which should not do consindering that defeats its purpose.
Old Oct 13, 2007 | 03:25 PM
It should compress a little..cause I think the idea is to take some of the initial shock when mainly shifting. So it should move some but not a lot
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
