Intermediate shaft
Intermediate shaft
anyone completely take if off, i need pointers. i have the 3 15mm head bolts disconnected from the bracket but cant get it to really budge past that.
thats my guess i would bet their is let me see what alldata says
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle.
Remove the RH tire and wheel assembly.
Disconnect the ball joint pinch bolt. Refer to Lower Control Arm Replacement.
Rotate the steering knuckle to access the wheel drive shaft inner joint.
Assemble the J 45341 and the J-2619-A to the wheel drive shaft inner tripot housing assembly.
Intermediate Drive Shaft Replacement
Tools Required
J 45341 Rear Wheel Drive Shaft Removal Tool
J 2619-A Slide Hammer with Adapter
J 44394 Seal Protector
Removal Procedure
Using the J 45341 and the J-2619-A, separate the wheel drive shaft from the intermediate drive shaft.
Reposition and support the wheel drive shaft from the intermediate drive shaft.
Inspect the wheel drive shaft-to-intermediate drive shaft seal (1) for excessive wear, damage, and/or contamination and replace if necessary.
Remove the rear, or LH intermediate drive shaft bracket-to-engine block bolts.
Remove the remaining intermediate shaft bracket-to-engine block bolt (2).
Using care to not damage the transaxle output shaft seal (1), remove the intermediate drive shaft assembly.
Inspect the transaxle output shaft seal (1) for damage and/or contamination and replace if necessary.
Installation Procedure
Install the J 44394 into the transaxle output shaft seal (1).
Install the intermediate drive shaft into the transaxle until the drive shaft splines are past the seal (1), remove the J 44394, then fully install the drive shaft.
Install, but do NOT tighten the intermediate drive shaft bracket-to-engine block forward, or RH bolt (2).
Notice: Refer to Fastener Notice in Service Precautions.
Tighten the intermediate drive shaft bracket-to-engine block bolts, beginning with the upper bolt.
Tighten the bolts to 50 Nm (37 ft. lbs.) .
Apply a very small amount of grease, GM P/N 1051344 (Canadian P/N 993037), or equivalent to the splines of the wheel drive shaft inner joint.
Install the wheel drive shaft into the intermediate drive shaft.
Verify that the wheel drive shaft is properly engaged:
Grasp the inner tripod housing and pull the inner housing outward. Do NOT pull on the wheel drive axle shaft.
The wheel drive shaft will remain firmly in place when properly engaged.
Install the tire and wheel assembly.
Lower the vehicle.
Inspect the transaxle fluid level.
Š 2008 ALLDATA LLC. All rights reserved.
Terms of Use
it wont let me copy the pics
Tools Required
Removal Procedure
Lower the vehicle.
Terms of Use
Last edited by boostedss26; Dec 26, 2008 at 05:37 PM. Reason: Automerged Doublepost
if all else fails, get a bigger hammer...... lol jk
sometimes they get stuck, get a prybar and go from where it connects to the tranny and try to pop it loose, we had to do that on a malibu when i worked at gm
i need to get the black intermediate shaft that runs between the tranny and the passenger side axle out.
both axles are out, i just need to get this out and i cant
Turbo Johnny
Feb 21, 2019 09:41 AM
