Keeping everyone in the loop
Old Aug 2, 2008 | 06:40 PM
lsjwannabe's Avatar
Well last month on the 26th i was out with my car tooling around with it and third gear decided it was time to go. So we tore everything out of the car leaving it a shell and i have some pics of the damage.
Both stage 2 axles where damaged as well the fluid in the cv boot leaked into the trans, as well as the splines started to grind and shear of metal to.
On the lighter side here is the motor
The killer chiller came a day after the trans went
Should be two weeks and everything should be together, the trans will be cryo'd, intake manifold on, and killer chiller on.
Old Aug 2, 2008 | 06:41 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
How did you pull this off?
Old Aug 2, 2008 | 06:42 PM
ecotecon18s's Avatar
I just cringed...OUCH...
Old Aug 2, 2008 | 06:45 PM
camarokiller's Avatar
Is there such a thing a tooling around when you have a TVS?
Old Aug 2, 2008 | 06:46 PM
ItalianJoe1's Avatar
Looks yummy!!
Sucks though, but a nice cryo'd tranny will be a good upgrade for you.
BoostedYards86's Avatar
WOW thats just nasty.
Old Aug 2, 2008 | 06:47 PM
BradSi's Avatar
Ouch. Tough break man. Hope it all goes smoothly from here.
Old Aug 2, 2008 | 06:50 PM
M-Dub's Avatar
Okay Cobalt SS + TVS = something breaks! Atleast you didn't pop the motor!
Killer Chiller..... hmmmmm
Old Aug 2, 2008 | 06:52 PM
Doc's Avatar
Doc
I want to look at this later....
Old Aug 2, 2008 | 06:57 PM
wannabe, i heard the tranny is a PITA to get apart, something about needing some kind of press or something? A GM tech told me they dont even repair the ss/sc trannys, they just get remans and swap them out...
Hell, while you're in there throw that Quaife 6speed in it and THEN cryo it!!! Do it right the first time!!! LULZ
Old Aug 2, 2008 | 06:59 PM
Z Speed's Avatar
same thing happened to my driver side stage 2 axle
Old Aug 2, 2008 | 07:04 PM
06 GM CobaltSS's Avatar
Hurts to see this.....
Old Aug 2, 2008 | 07:31 PM
lsjwannabe's Avatar
i considered this but its to much $$$$ and i have to be back on the road with this thing i have many commitments to fufill with it.
just driving really quick pull in second to 5.5k and up shifted and nothing but a bunch of metal clanging around.
Not really me and josh got the motor and trans out in about 4 hrs and it only took 30 mins to take the trans apart to there.
Originally Posted by ItalianJoe1
Looks yummy!!
Yeah then next goes the motor
Yes i am very interested on the results this and the ported intake will allow, especially at my level.
Old Aug 2, 2008 | 07:32 PM
BlackSS/SC's Avatar
One of my stage 2 axles had that happen to it too. Same thing!
I noticed it when I pulled the tranmission to do the clutch a couple months ago. That little stub shaft stayed in the transmission and cv grease had made its way into the transmission. They warrantied the shaft, no questions asked.
But ****! Why are they doing this? I only ran mine for a month before I found it like that.
So are you upgrading the transmission at all? If it's possible keep me in the loop because I have a feeling this will be happening to me soon
Old Aug 2, 2008 | 07:33 PM
lsjwannabe's Avatar
Yep sucks but they warrantied them for me just had to be shipped so i could not complian really.
Trans is just getting cryo'd i looked at it hard and long and can't justify a f40 or quaife swap at this point.
Hopefully if everything goes right my dealer will cover all the trans parts to.
Old Aug 2, 2008 | 07:46 PM
BlackSS/SC's Avatar
Got friends at the dealer do ya?
So to get the trans parts cryo'd, do you have to take the gears off the shaft? Are you getting every single metal part done? I need to start looking into this too so I can get it done over winter.
Old Aug 2, 2008 | 07:51 PM
Josh@ottp's Avatar
We are getting everything cryoed even the case. I will be disasembling it all and yes you need some special tools and a press.
Old Aug 2, 2008 | 07:59 PM
BlackSS/SC's Avatar
I've got a complete shop at my disposal filled with tools but not the special ones for this transmission
Old Aug 2, 2008 | 08:01 PM
lsjwannabe's Avatar
Thats were the dealer comes into play
Old Aug 2, 2008 | 08:28 PM
Josh@ottp's Avatar
Well if you dont have a puller with very thin teeth you won't be getting 5th gear off. It's one of those either buy the right tool or make your own situation, otherwise you will chip teeth.
Old Aug 2, 2008 | 08:53 PM
BlackSS/SC's Avatar
I surely don't want to chip any teeth. I have a hookup with a gm dealer here but I've never asked them if they have the tools. I doubt they do though.
Old Aug 2, 2008 | 09:02 PM
SCBLKRL's Avatar
sucks to hear this....can't wait for you to have it back up and running.
Old Aug 2, 2008 | 09:04 PM
lsjwannabe's Avatar
Yeah i figured something would have to give, i just figured it would be the motor first
Old Aug 2, 2008 | 09:05 PM
SCBLKRL's Avatar
that was my thought as well wonder if it will be the same for me or not when I get to that point.
Old Aug 2, 2008 | 09:06 PM
jsscooby's Avatar
holy **** that poor gear
