KY Clutch - Interest Thread
Old Jan 10, 2012 | 07:18 PM
EXsoccer1921's Avatar
hey aaron did you ever look into my inquiry a little more?? season starts march 3rd CDRA starts in april
Old Jan 10, 2012 | 07:29 PM
TurboTechRacing's Avatar
PM me again... Spring rush I think is already at its start around here!
Old Jan 10, 2012 | 10:50 PM
Chevycobaltss3's Avatar
Bump guys. we are doing this to help the cobalt community. This clutch has proven it self and also carries a great price. We will update the thread. We should find prices tomorrow.
Thanks.
Old Jan 10, 2012 | 11:01 PM
Yup, and I will get ahold of KY and find out about a full faced disc option for the stage 2 and stage 3.
Old Jan 10, 2012 | 11:04 PM
Dart_SI's Avatar
Old Jan 10, 2012 | 11:07 PM
Ok, and ill be ready to get any info needed. Aaron you have my cell, so if you need anything let me know.
Old Jan 10, 2012 | 11:10 PM
TcKid631's Avatar
Nice, will be needing a clutch before spring. looks like I found where i'll be purchasing my next clutch
Old Jan 11, 2012 | 01:17 PM
jmfselu's Avatar
bump for KY and TTR. can not wait to hear this offer.
Old Jan 11, 2012 | 01:42 PM
We are working on full face disc stage prices, and then we will post all the prices at one time
Soon... We promise... Soon...
Old Jan 11, 2012 | 01:55 PM
Gremlin85's Avatar
I'm in for sure.
Just need a transmission now.
Old Jan 11, 2012 | 02:41 PM
  #36
I have a few blown ones hint
Old Jan 11, 2012 | 04:24 PM
  #37
Ok guys just a heads up, we have discussed most but we are still trying to figure pricing on a few clutchs.. (mainly the full faced discs) for drivability purposes.... We are searching around for the best materials and at a good price so you all may get the best pricing for the clutch.. also know that the materials used in these kits are a+ materials . Turbotechracing is already apart of our community and when the deal is done, ky clutch will be here for the community.Thanks to Aaron for being part of the #1 vendor "turbotechracing". Without his opinion about kyclutch this wouldnt be happening.
.thank you Aaron.
Old Jan 11, 2012 | 04:27 PM
  #38
Gremlin85's Avatar
Awesome!
Thanks guys, it's greatly appreciated!
A wonderful thing bringing easier access of these clutches to the community. I'll be first in line
Old Jan 11, 2012 | 06:55 PM
  #39
sponge14's Avatar
Awesome, can't wait to see the prices and capabilities of the full faced clutches.
Old Jan 11, 2012 | 08:40 PM
  #40
Since we are still waiting on a couple pricing things with KY. I did want to pass on and address your post.
I will try to post this as clearly as possible so everyone can understand.
Topic: Discs in Clutch Kits - Puck VS Full Face.
What is a Puck style Disc?
Just as it sounds, it will have 4, 6 or 8 "pucks" most times.
What is a Full Face Disc?
Just as it sounds, it will have full face, in which looks like a washer.
Next: What is the difference.
When using the same material and same pressure plate, a Puck design will hold more torque. You may ask: Why?
Lets take for an example a 2,000 lb pressure plate.
The Puck disc has 6 pucks at 6 IN^2 of surface area each puck. Total surface area then is 36 IN^2 (6 Pucks Times 6 SQ Inches per Puck)
The Full face disc has a constant surface material, the total surface area of 72 IN^2.
With the stated example of a 2,000 lb pressure plate:
On the Puck style would have a pressure of ~55 lbs per square inch of material.
On the Full Face style would have a pressure of ~26 lbs per square inch of material.
With this being stated a Puck style will hold more torque.
Press down lightly on a piece of paper and pull. Then do again and press down twice as hard and pull. The harder you can push on the same area, the more it does not want to move.
However the Puck design will generally wear out faster, as there is less material on the puck. Full face will last longer, as it has more wearable material.
Keep in mind there is more to clutch discs than what we just reviewed, for exmaple materials of the disc, diameters, ect. In addition pressure plate force/lbs.
I hope this helps some?
Old Jan 11, 2012 | 08:47 PM
  #41
we are almost there guys.. it shouldn't be to long now. We are all doing our best..
thanks Aaron
Old Jan 11, 2012 | 09:20 PM
  #42
Also pucked style clutches, wether they are full faced with pucks,or a actual pucked friction disc. They dissipate heat and make it easier to hold power longer. Now having the full face puck disc will lose some of that benefit but its still able to hold the power . Full faced discs non pucked lose the abilty to keep the power because of the above but a lot of it is due to the heat transfer. If there are any technical questions out there about ky clutches, shoot me a pm please we are here for the community.
Thanks guys.
Old Jan 11, 2012 | 09:29 PM
  #43
EvilleCobalt's Avatar
I planned on ordering a KY clutch sometime in the spring. If you guys start carrying them I'm definitely interested.
Old Jan 11, 2012 | 09:32 PM
  #44
conerboner's Avatar
Awesome news!!! I'll definitely get one if my spec doesn't hold up lol
Old Jan 11, 2012 | 09:56 PM
  #45
vahdyx's Avatar
Thanks for the info, now I know more about clutches.
The only concern I have with KY is drivability, but if it's just as good as stock then I'd be interested for sure.
I had already planned on getting a ZZP stage 4, but I think having TTR having it readily available will cause more people to have one, thus making more reviews and perhaps one day someone in Colorado will get one and I can test it out.
Old Jan 11, 2012 | 10:09 PM
  #46
Drivability on any clutch will be different then stock. You can have a relatively close pressure feel but never the same. Ky clutches pressure change with pressure plate clamping force , which is somthing they test on every clutch setup they send out. And the given pressure is given with clutch stages. When we have the full faced discs ready we will get you the technical data like material, and Tq capacity along with plate pressures ..
Thanks guys.
Old Jan 11, 2012 | 10:23 PM
  #47
Dart_SI's Avatar
The ability to slip it like a stock clutch is what I want. Helps a lot with launching at the track and just makes daily driving better. I don't care if the clutch is a little stiffer.
Old Jan 11, 2012 | 10:28 PM
  #48
We will do our best to get one made. Also if anyone has specific questions ask me.. I'm here lol
Old Jan 11, 2012 | 10:41 PM
  #49
vahdyx's Avatar
Oh hell yeah I agree with Dart_SI but if you guys do make a full faced one that holds good and can slip, you guys can have my money. Well for a clutch of course, but still.
Old Jan 11, 2012 | 10:50 PM
  #50
Yeah we are gonna do our best
