Lightweight Pulley
Old Feb 24, 2008 | 01:13 AM
116Fanatic's Avatar
Lightweight Pulley
Anyone else agree with me that a supporting vendor should make a lightweight pulley for our cars? I forgot exactly what the pulley is called to be honest...but I am not talking about a supercharger pulley. Anyone wanna help me out if you know what I'm talkin about?
Old Feb 24, 2008 | 01:14 AM
SlowBalt_06's Avatar
they do and its like 300 bucks through jbp crank pulley?
Old Feb 24, 2008 | 01:52 AM
Sharkey's Avatar
lightweight crank pulleys do nothing. the only situation were you will see any gains with one is if its an underdrive pulley, and the gains will be small and proportionate to the amount of things driven by that pulley. an ecotec only drives the alternator and a/c (when its off there is no drag). you would see higher gains if it drove the alternator, power steering pump, water pump, and a/c.
short answer- dont bother.
Old Feb 24, 2008 | 01:54 AM
redlineblueline's Avatar
and supercharger if you have one
Old Feb 24, 2008 | 01:55 AM
06' SS2SS's Avatar
RSM makes one.
Old Feb 24, 2008 | 08:19 AM
Stouffer's Avatar
I believe Crate Engine Depot sells the JBP
Old Feb 24, 2008 | 08:49 AM
M-Dub's Avatar
Smoothflow pulleys are billet aluminum and prolly a quarter of the weight of the cast units!
Old Feb 24, 2008 | 08:57 AM
JBP is supposedly making a lightweight alternator pulley as well. If you coupled that with a lightweight crank puelly also would that be worth it?
Old Feb 24, 2008 | 12:23 PM
Nyke's Avatar
Is the motor internally balanced or does it used the crank pulley (Harmonic Balancer) to balance it out?
I do not know but I do know that if you put a lightned pulley on a non-interally balanced motor your crank bearing will wear out faster and will cause huge problems down the line.
Old Feb 24, 2008 | 02:09 PM
jbps pulley is supposedly leightweight but still balanced
Old Feb 24, 2008 | 02:36 PM
http://www.atiperformanceproducts.co...ts/damserp.htm
Old Mar 4, 2008 | 01:06 PM
ijak's Avatar
that is not true at all....even a pound in difference of the crank pulley generates way more power because when it starts spinning the centripetal force becomes much less in comparison of the heavy one...in another words...it takes probably 100-200lbs off ur car during movement.
Old Mar 5, 2008 | 12:03 AM
116Fanatic's Avatar
Does anyone know which of the engines(2.0, 2.2, 2.4) share the same pulleys? I mean that are interchangeable?
Old Mar 5, 2008 | 11:30 AM
Dragonsfire12345's Avatar
I believe the 2.2 and 2.4 are the interchangeable.
Old Mar 6, 2008 | 09:07 AM
celicacobalt's Avatar
yeah, on the celica a light weight crank pulley will cause issues with the oil pump. its die to the removed harmonic balancer. Only way id use one is if its proven to be balanced and still light weight but not underdriven.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
