lost 2nd 4th an Reverse!!
well about a month ago i noticed when shifting i had to really pull hard to get it in gears 2 4 an Reverse. It would only grind if it wasnt in all the way when i let the clutch out. The other night i shifted into second kinda hard
...... when i shifted into 3rd it was fine then i tried to down shift into 2nd an it didnt go in all the way so i tried a second time an it felt loose an wasnt there. I noticed 4th an revers was also mia. but 1st 3rd an 5th work fine. no grinds not hard to get in at all.
i pulled the cup holder but i have no clue what to look for..... i mean when i pull down to second right now it just moves over like its in 4th/N
BUmp cause i need help.. !!!!
the cables still seem attached. when i move the shifter they both move. except the black on in the pic above the metal is showing. looks more like the one with the white clip.
thanx bro.. i just took it to the dealer..lol ill let them deal with it cause they also messed up my valve cover gasket when they fixed the timing chain tensioner an they also need to fix my sunroof switch an trim cause it fell out. soo hopefully they get it. Thanx for everyones help though.
This happened to me. Three times in a row. . .
Gm had to give me a new tranny because something inside the actual trans broke.
I wish you the ebst of luck on that one and make sure they re-assemble your drivetrain properly . .. that was another headache all on its own.
Sounds like the shift linkage broke. By the spot where BoomInIt stated, the sheathing is a cheap plastic that breaks easy and once it does the cable no longer has a proper guide to the tranny causing it flop around and crimp up eventually not permitting you to get in gear. $110 part if I remember correctly.
I am glad that I am not the only one with transmission issues right now. Mine would sometime not go into reverse without putting hte car in first and rocking it and it would randomly pop out of 5th. I am waiting on the delearship to put a new transmission in it. I am now on week 2 without my car.
got my car back thursday like they aid when i dropped it off.
