lost 2nd 4th an Reverse!!
Old Feb 22, 2008 | 08:25 PM
SSBalt07's Avatar
well about a month ago i noticed when shifting i had to really pull hard to get it in gears 2 4 an Reverse. It would only grind if it wasnt in all the way when i let the clutch out. The other night i shifted into second kinda hard ...... when i shifted into 3rd it was fine then i tried to down shift into 2nd an it didnt go in all the way so i tried a second time an it felt loose an wasnt there. I noticed 4th an revers was also mia. but 1st 3rd an 5th work fine. no grinds not hard to get in at all.
Old Feb 22, 2008 | 08:27 PM
BLAZIN07SS's Avatar
I'm too JDM for you
pop off your cupholder in front of the shifter and make sure that both cables are in their clips. i had one pop out of its clip and i lost 2nd, 4th, and R
Old Feb 22, 2008 | 09:10 PM
SSBalt07's Avatar
i pulled the cup holder but i have no clue what to look for..... i mean when i pull down to second right now it just moves over like its in 4th/N
BUmp cause i need help.. !!!!
Old Feb 22, 2008 | 09:31 PM
rockkrawler628's Avatar
actually i think i saw a TSB for this... lemme know what happens
Old Feb 22, 2008 | 09:35 PM
nhcobalt's Avatar
there is a tsb for this issue i need to get my car in as well, the dealer said it is the syncros are malfunctioning.
Old Feb 22, 2008 | 09:40 PM
njg5gt's Avatar
sounds like one of your cables came off in the shifter linkage under the cup holders. should look like this...
Old Feb 22, 2008 | 11:42 PM
SSBalt07's Avatar
the cables still seem attached. when i move the shifter they both move. except the black on in the pic above the metal is showing. looks more like the one with the white clip.
Old Feb 24, 2008 | 06:32 PM
BoomInIt's Avatar
Under your hood remove the fuse box then there are 2 linkage cables to the tranny. Hold the cable and pop the plastic shroud back in. That should be your fix...it was for me.
Old Feb 25, 2008 | 04:10 PM
SSBalt07's Avatar
thanx bro.. i just took it to the dealer..lol ill let them deal with it cause they also messed up my valve cover gasket when they fixed the timing chain tensioner an they also need to fix my sunroof switch an trim cause it fell out. soo hopefully they get it. Thanx for everyones help though.
Old Feb 28, 2008 | 02:31 PM
BlkDragon SS's Avatar
This happened to me. Three times in a row. . .
Gm had to give me a new tranny because something inside the actual trans broke.
I wish you the ebst of luck on that one and make sure they re-assemble your drivetrain properly . .. that was another headache all on its own.
Old Feb 28, 2008 | 02:36 PM
2K5SS/SC?'s Avatar
Sounds like the shift linkage broke. By the spot where BoomInIt stated, the sheathing is a cheap plastic that breaks easy and once it does the cable no longer has a proper guide to the tranny causing it flop around and crimp up eventually not permitting you to get in gear. $110 part if I remember correctly.
Old Feb 28, 2008 | 02:41 PM
refuge4's Avatar
I am glad that I am not the only one with transmission issues right now. Mine would sometime not go into reverse without putting hte car in first and rocking it and it would randomly pop out of 5th. I am waiting on the delearship to put a new transmission in it. I am now on week 2 without my car.
Old Feb 28, 2008 | 11:15 PM
2K5SS/SC?'s Avatar
I've been through 2 tranny's already, do you're actually behind one!
Old Mar 2, 2008 | 01:50 PM
SSBalt07's Avatar
it was the roll pin... got my car back thursday like they aid when i dropped it off.
Fearedbynone
Apr 14, 2016 03:25 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
riceburner
Oct 2, 2015 05:47 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
jrocstar
Sep 26, 2015 11:42 PM
