Low brake fluid
Low brake fluid
I rebuilt the engine, put it all back together and the brake fluid is now going low. I know the clutch uses the reservoir, am I missing something? Seems like there is a small leak under the car also.
Whenever you take the transmission out, it is a good idea to replace the slave cylinder if it hasn't been replaced recently.
And yes, the clutch slave does share the same reservior as the brake system, so if the reservior goes low its probably the slave cylinder leaking.
