LSJ vs LNF Tranny
Old Feb 21, 2015 | 12:44 AM
LTBALTBMX's Avatar
LSJ vs LNF Tranny
Has anybody noticed that the LSJ tranny is much smoother to shift than the ones in the LNF. I know they're not identical, but the only difference is the final drive ratio. That should'nt affect the feel of the shifter...
Could it be the stock short shifter itself in the LNFs causing uber roughness? Maybe I should throw in a stock SC shifter to see how it feels. Has anybody tried this?
Old Feb 21, 2015 | 11:24 AM
Sounds like you need to adjust your shifter cables.
I'm pretty sure the shifters themselves are the same, cable holder is a little different with the LNF its stronger and LSJ guys use the LNF part.
Old Feb 21, 2015 | 11:54 AM
BoostedLemonPie's Avatar
I was looking at buying that revised bracket from CED along with a slu of other parts. For less than 30 bucks too.
Old Feb 21, 2015 | 12:38 PM
LTBALTBMX's Avatar
I've done all that. The two SS/SC's I've owned have a fundamentally different feel in the shifter. They feel more like a Honda shifter while my SS/TC's feel more like a... Chevy
Same goes for the F23 in my LT, its notchier than a jagged saw blade.
I recalling reading a FAQ on here which states the SS/TC comes from factory with a short shifter. Better verify by looking at part numbers.
Edit: yup they're different 25815049 for the LSJ, 20763152 for the lnf. The shift cables are different too 10383794(lsj) vs 25798498(lnf)
Old Feb 21, 2015 | 12:39 PM
RyBread761's Avatar
Originally Posted by LTBALTBMX
Has anybody noticed that the LSJ tranny is much smoother to shift than the ones in the LNF. I know they're not identical, but the only difference is the final drive ratio. That should'nt affect the feel of the shifter... Could it be the stock short shifter itself in the LNFs causing uber roughness? Maybe I should throw in a stock SC shifter to see how it feels. Has anybody tried this?
I didn't think the LNF had a short throw...I feel like I am in the Dad Veil Regatta in that car sometimes...can't wait to get my BPS shifter installed
Old Feb 21, 2015 | 12:41 PM
chris88z24's Avatar
The LSJ has a short shifter too.
I think the cables are different. The LNFs always seem to have issues with the shift cables. I have yet to see an LSJ on here with cable issues.
Old Mar 3, 2015 | 05:12 PM
SaberD's Avatar
The LNF uses a different shifter bracket. I put the LNF one on my LSJ, and felt more direct communication between the trans and shifter. The LSJ one makes it feel more smooth and sloppy.
GM ACDelco - Revised Shifter Bracket for LSJ #GM-55563732
Old Mar 3, 2015 | 08:53 PM
ae_xiong's Avatar
Is the final gearing on the lsj 4.05 vs 3.82 in the lnf?
Old Mar 4, 2015 | 12:22 AM
Its the opposite
Old Mar 4, 2015 | 12:25 AM
Its the opposite
Rice he's got it right
Old Mar 4, 2015 | 01:04 AM
slapbetcommissioner's Avatar
Correct.
Old Mar 4, 2015 | 07:30 AM
Staged07SS's Avatar
Administrator
Administrator
The difference between the SS/SC shift cable bracket and SS/TC is the SS/TC's is solid, and the SS/SC has rubber bushings which can cause a vague feel while shifting.
Neither bracket is "stronger" than the other though.
I just installed the SS/TC shift cable bracket and solid base bushings and the shifter def feels tighter and more direct. Nothing cray cray though.
Both cars technically have a "short throw" shifter compared to the base models, and that is kinda what Chevy was prob getting at. They are not as short as aftermarket of course.
I know the SS/SC's throws were reduced from the Saabs when it first came out.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
OrangeCoba
Oct 1, 2015 10:00 PM
patooyee
Oct 1, 2015 01:07 PM
