Need Help ASAP
Old Mar 6, 2014 | 09:28 PM
08baltls's Avatar
Need Help ASAP
Im pretty sure my roll pin is shot and I need to replace it tomorrow morning. I need to know what size roll pin I need pr what size bolt. I found the how-to for this and it mentions a bolt. Will it be safe to run a bolt instead of a roll pin? How tight should I tighten the nut on it? Etc. Just need some help before I go to buy this stuff.
Old Mar 6, 2014 | 09:47 PM
redcobalt07's Avatar
are you planning on just running the bolt until tomorrow morning?
Old Mar 6, 2014 | 09:55 PM
BlkWdoSS's Avatar
it would need to be a high grade bolt, I would say minimum of grade 8. otherwise, the roll pins are usually readily available at dealerships and fairly cheap to get several
Old Mar 6, 2014 | 09:58 PM
08baltls's Avatar
Well I was gonna run the bolt instead of the roll pin so I dont have to worry about going through them. Granted this is the first time I'll have to replace it and the cars got 81k on it.
Napa has roll pins for like $0.25 a piece. I may probably just end up buying those cause I'd hate to **** the trans by using a bolt instead of a part designed to fail. Another question, is changing the roll pin the same for the F23 as it is for the F35?
Old Mar 6, 2014 | 09:59 PM
no place is going to stock a grade 10 bolt. In fact grade 10 bolts aren't even made
Old Mar 6, 2014 | 10:01 PM
Originally Posted by BlkWdoSS
it would need to be a high grade bolt, I would say minimum of grade 10. otherwise, the roll pins are usually readily available at dealerships and fairly cheap to get several
How much pressure do you think that pin is supposed to take?
Old Mar 6, 2014 | 10:07 PM
08baltls's Avatar
From reading through the how-to, now Im wondering, my shifter has a **** ton of play side to side, not so much front to back. Would that still be a roll pin or would it be something else?
Old Mar 7, 2014 | 09:27 AM
cw383's Avatar
1" X 3/16 Is what you need. Ask for a "roll pin pusher" too.
Old Mar 7, 2014 | 09:37 AM
blueLNFftw's Avatar
When the roll pin breaks you cannot select gears
Cobe
Sep 19, 2015 11:04 AM
06noscobaltss
May 25, 2006 01:55 PM
Saki XL
May 16, 2006 01:34 AM
9JordonFlex9
Mar 26, 2006 08:05 PM
Cobalt30
Mar 11, 2006 02:50 AM
