need help fitting axels please!
Old Jun 6, 2009 | 04:35 PM
bernandovelasquez's Avatar
Good day, I bought those axels from OTT the other day, and today I wanted to install them, so I went ahead and installed the driver side which went smoothly, but when I go to install the passenger side, I notice this whole side of the car had different parts!!!! the control arm was not even aluminum!!!! so I figgured the car was hit before I bought it and the person who fixed it decided to use cheaper parts (probably from the lt) on the car.... any way now when trying to fit in the new axles, it turns out the bearings on the axle for the SS is bigger than the ones on the LT, so now I need to replace the shaft the comes out of the gearbox of which the axles are suppose to slide into for the ss model which have a bigger housing to take the bearings of the axle of the ss model.... does anyone know what that part is called?? it's the shaft that goes into the gearbox of which the axles slides into.
bump for urgent help please.
Last edited by bernandovelasquez; Jun 6, 2009 at 04:35 PM. Reason: Automerged Doublepost
Old Jun 6, 2009 | 05:45 PM
Cefaln452's Avatar
hmm which axles did you get? DSS or stage 1's
Old Jun 6, 2009 | 06:01 PM
Sharkey's Avatar
are you talking about the shaft between the tranny and the axle, or the wheel bearing??? if its the shaft between the tranny and axle, only the ss/sc or ss/tc uses that, the other models use one long axle. if your saying that the axle wont slide into the wheel bearing, im not sure what to say. i didnt think the ss/sc used a different wheel bearing than an 2.4l ss. if they did change the knuckle/wheel bearing to something other than an ss/sc, it would have had to be a 2.4ss as ss brakes wont bolt to a non ss knuckle.
Old Jun 6, 2009 | 08:32 PM
hey man thank you I will try to find that part online, do I search for knuckle wheel bearing ??
Last edited by bernandovelasquez; Jun 6, 2009 at 08:32 PM. Reason: Automerged Doublepost
Old Jun 6, 2009 | 09:31 PM
qwikredline's Avatar
reading what you wrote it seems you need an intermediate shaft and bracket complete I have some of those you have a Cobalt right? pm me if you need this or talk to OTTP I can work thru them thanks qwikredline....
Last edited by qwikredline; Jun 6, 2009 at 09:31 PM. Reason: Automerged Doublepost
hacadacalopolis
Oct 28, 2015 06:09 PM
cavfiredesire
Oct 3, 2015 08:02 PM
jmelton327
Wheels and Tires
Oct 2, 2015 01:54 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Delta coupe
Sep 30, 2015 08:11 AM
