New Clutch install question
Old Feb 7, 2010 | 10:40 AM
jrzdude's Avatar
I just purchased the Centerforce clutch kit, and was wondering if there was anything else I would need to buy? I read on here that a few people were buying the LNF slave cylinder from GM. Can everything (bolts, gaskets, etc..) be re-used? This is my first clutch install on this car, so I'm not too familiar with everything yet. Any advice would be appreciated. Thanks!
Old Feb 7, 2010 | 12:48 PM
selfinfliction's Avatar
not sure if the centerforce comes with flywheel bolts, but i always replace them too. u need to get your flywheel resurfaced if you didn't get an aftermarket one.
if you want a slave cylinder, i have an extra brand new LSJ model one i can sell you for $30 shipped.
Old Feb 7, 2010 | 02:30 PM
jrzdude's Avatar
yes, it came with a new lightweight flywheel and a pressure plate. I heard that the LNF slave's are supposed to be better. There's nothing wrong with the one i have now, just wanted to see if it was necessary to buy a new one with an upgraded clutch and flywheel
Old Feb 7, 2010 | 04:00 PM
Doesn't matter if your slave is good or not, replace it with a new one or risk 10 more hours of labor down the road cause u were too cheap to spend less than $50
why would u spend that much money on a clutch if you're only running a stage 2?
Old Feb 7, 2010 | 11:04 PM
kxrida2000's Avatar
replace both slave and flywheel bolts they are a one time torque thing...once they are torqued i believe they are much weaker
Old Feb 8, 2010 | 05:01 AM
jrzdude's Avatar
Cuz I have a TVS, Meth kit, HE, and 79's getting ready to be put on. And I'm not cheap, just want to do it right the first time, which is why I was asking. Thanks for the advice
Alright, gotcha. Thanks!
Any other advice or tips before I rip into this monster?
Old Feb 8, 2010 | 05:42 AM
YzRider452's Avatar
Only tip is take ur time and do it right. Took me and my buddies about 14 hours to do his.
Old Feb 8, 2010 | 06:27 AM
LaserBlue07SS's Avatar
You will need new Fly wheel Bolts they are one time use. ( torque to yield bolts ). Highly recommended that you replace the Slave cylinder as your already in there and why g through all that work if it fails down the road.
Old Feb 8, 2010 | 11:58 PM
jrzdude's Avatar
So is the LNF Slave supposed to be better? Can I buy the flywheel bolts from the dealer as well?
Old Feb 10, 2010 | 03:24 PM
PolishPauL's Avatar
http://www.crateenginedepot.com/stor...P2301C229.aspx
They strongly recommend you also replace the Cobalt Clutch Pipe 24422067 when you replace your clutch.
Old Feb 10, 2010 | 03:57 PM
nicksredline's Avatar
yeah keep tellin him i need to knwo also... so u need bolts, resurface, clutch, pipe, slave cylinder,what elce??
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
brandon04
Oct 21, 2015 07:04 AM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
Bohb
Sep 27, 2015 09:11 PM
