New clutch master cylinder, blows clutch line off when trying to bleed?
Old Apr 7, 2019 | 03:56 PM
Jrflint09's Avatar
I have a 2005 cobalt ss, all stock. New clutch, slave and TB. Lost clutch pedal about 500 miles after new clutch install. Just installed a new clutch master cylinder. I have vacuum bled it and still cant get any tyoe of pedal. When I manually bleed it, it develops a hard spot in the pedal and when I press it down it blows off the clutch line that is attached to the clutch master cylinder. And the clip is installed correctly i have already checked. Any help would be greatly appreciated.
Old Apr 7, 2019 | 06:27 PM
63 Nova SS's Avatar
Are you totally sure the clip is correct? It's really hard to tell sometimes till you put the pressure to it.
Old Apr 7, 2019 | 06:34 PM
Jrflint09's Avatar
Yes ive taken it complet9off and reinstalled it, I even tried using the the clip off of the old one still no luck
Old Apr 7, 2019 | 07:14 PM
C0balts5's Avatar
Maybe the clutch line itself is faulty, the clip is probably being installed correctly but the locking grooves the the clutch pipe itself are boogered. You can get a new clutch line off of zzp performance website
Old Apr 7, 2019 | 08:12 PM
Jrflint09's Avatar
I just ordered one from zap so i will let u know as soonnas it gets here and I install it
Old Apr 7, 2019 | 08:13 PM
Jrflint09's Avatar
Zzp
Chevy_life2146
Dec 9, 2015 12:02 AM
etnies
Dec 15, 2012 06:57 AM
Iam Broke
Mar 11, 2012 04:48 PM
cobaltshawn
May 11, 2011 09:50 PM
DeepBlack SS
Sep 26, 2009 03:03 AM
