New to a stick
Old Aug 1, 2006 | 12:14 AM
GTPUSER's Avatar
Originally Posted by KeystoneSC
There is no set point...vehicles vary.
On my SC...3.5 is optimal for 1st, 2.9 for second, 2.7 for third and around 2.4/2.5 for 4th/5th. I do a LOT of driving (110 miles one way to work) and I have tried the full range. This has given me the best MPG for MY vehicle. It will vary from vehicle to vehicle...so just try a few and see how it works for you. Mind you...this is for REGULAR driving.
If speed is the motivation...things are entirely different.
Why do you drive 110 miles to work, is that a once a week thing?
Old Aug 1, 2006 | 01:28 AM
chipmonk212121's Avatar
Ok... shift at about 2500 rpm..... 2k is a little low and 3k isnt bad but 2500 is best....
and B
DO NOT GO ON WHAT THE STUPID DIGITAL DISPLAY SAYS.........
you do NOT get as good of gas mileage as what it says so STOP using it!!!!
i measured mine the correct way and i got 23 when the stupid display said 26. kinda like when the temperature outside is "104" that is incorrect as well.
Old Aug 1, 2006 | 01:47 AM
REIGN SS's Avatar
Original Hayden Fanatic
Driving with your RPM's below 2000 is hard on your transmission. Takin it easy is one thing but shifting @ 2500rmp is just silly, you end up in 5th @ 40MPH lol...
Old Aug 1, 2006 | 01:56 AM
you will be at about 2300rpm if you are goin 60 in 5th and around 50 at 2k rpm. 2500 rpm is the normal shifting rpm on a automatic car driving easy..... so it isnt silly
Old Aug 1, 2006 | 06:38 AM
DanteMustDie's Avatar
automatic trannys is a hugely different animal... it's not the same at all when shifting low for a manual. It IS hard on the tranny. What do you think those vibrations in the pedal are when you shift so low and get on the gas again ?
Old Aug 1, 2006 | 08:53 AM
i have 0 vibration unless I try shifting at about 1500 RPM
Old Aug 1, 2006 | 09:58 AM
fishdude56's Avatar
I try to shift around 2000rpm to save gas. I also try and stay in 5th even when im doing 40(You don't get any acceleration though). The more rolling you do, the better mpg's you'll get.
Whats the sence of saving gas if your not goin to burn it every once in a while!
How to Guide
57
Oct 15, 2015 11:56 AM
dieGone
Sep 23, 2015 10:20 AM
QuickSilver_SS
Sep 17, 2015 05:38 PM
QuickSilver_SS
Sep 17, 2015 11:23 AM
