Newb Question
Old Jun 22, 2006 | 06:45 PM
116Fanatic's Avatar
Question Newb Question
I don't know too much about cars...What does horsepower affect and what does lb/ft. torque affect?
Old Jun 22, 2006 | 06:49 PM
Beck's Avatar
april fools?
Old Jun 22, 2006 | 06:51 PM
snobird's Avatar
116Fanatic's Avatar
No...seriously
Old Jun 22, 2006 | 06:55 PM
snobird's Avatar
In car terms, torque is the outside force. It is what actually moves the car. Horsepower is derived from torque, and is relative to time. In order to address these terms you need 3 things force work and time
tourqe bascially is what gets the car going but once it gets higher speeds then hp keps it going
Tomtwtwtw's Avatar
The more have of either one, the more you want.
Old Jun 22, 2006 | 07:01 PM
116Fanatic's Avatar
Alright thanks. I asked because I was looking up intakes and the Injen adds 17hp & 16 torque( or somethin like that) and the AEM adds only 7hp but 17 torque...
Old Jun 22, 2006 | 07:11 PM
XM15's Avatar
Hey 116Fanatic; check out http://auto.howstuffworks.com/horsepower.htm I think that will answer some of your questions.
Old Jun 22, 2006 | 07:19 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
Originally Posted by 116Fanatic
Being in a Church makes you no more of a Christian than laying in a garage makes you a Cadillac. - The Fighting Temptations Movie.
Its not enough to believe in God, even Satan believes in God.
Its about living souled out for Christ and having a relationship with Him.
C F L = Christ For Life
Romans 1:16 - For I am not ASHAMED of the gospel of Jesus Christ for it is the power of God for salvation unto everyone who believes...
Not to high jack your thread but when I read your signature I just wanted to say hello, Hallelujah, and Amen.
Old Jun 22, 2006 | 07:27 PM
116Fanatic's Avatar
Thanks for the help & the hallelujah. That site cleared up a lot...but I still don't see how the AEM adds 17 torque and ONLY 7hp because they seem kinds directly related?
Old Jun 23, 2006 | 01:22 PM
NightmareRacing's Avatar
sigh,
torque is what matter, hp doesn't keep you going on the "top end", rather, the rate at which your torque is falling off from its peak is what keeps you going (in relation to the engine's rpm past the peak tq rpm)
HP= (Torque x rpm)/a constant (can't remember the number off hand)
so really, to make hp you either turn the rpm high or make a crap load of tq at a lesser rpm.... this is why you can have 2 cars making 1000hp, one at 9000rpm, the other at 6000 rpms...
The idea is to set your car properly for either motor, and both cars should be as fast
Also, your rate of tq at which it is falling off will affect your hp. Changing cams usually keep the falling rate prety low, so you end up with more hp on the top end (at sometimes the cost of lesser tq towards the low end), this also called a curve switch to the right, meaning the hole tq switch over to the right (in relation to the rpms), so you may produce the exact same amount of peak tq, but at a diff rpm, thus producing more hp.
that is all for now
Old Jun 23, 2006 | 01:30 PM
Tomtwtwtw's Avatar
Originally Posted by NightmareRacing
HP= (Torque x rpm)/5252
Saki XL's Avatar
sigh,
Don't you mean 5252?
Old Jun 30, 2006 | 10:12 AM
scottw03's Avatar
I don't know if it is different on a relatively stock S/C car than on a stock turbo car but on the SRT-4 an intake will not give you 17 HP / 16 lbs of torque. You might see a 3 hp gain but that is like it. Now on a big turbo (so maybe on a larger S/C) you might see a larger gain like 7-9 but I just don't see gaining that much with just an intake.
Usually if you want a decent gain for the money, swapping out your exhaust is a good way to do it. Exhaust should aways be one of your first mods done to the car. After that it is relative to the car and what your HP/TQ goal is.
Sorry, I am on here trying to learn more about the Cobalts since I have two friends that own them. That and the base has SRTforumdotcom locked down so I figured I can surf CobaltSS.net while at work and SRTforumdotcom while I am at home.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
