No Gears!!
No Gears!!
i was coming home tonight and bottomed out the car it put a hole in my oil pan and also i have lost every gear!! The shifter will go into all the gears but there is no resistance and the clutch does not need to be in but the car will not move. Its like the linkage is not hooked up but i looked and it is i dont know what else to look for. Also where do you find an oil pan for the 2.0 ss thanks. Any info will help
hey i looked tonight its deff my oil pan leaking called gm and they will take 3 months to get one! I then looked at the roll pin and it is half out so im guessing it is broke going to find out now ...
fixed the pin and the car shifts again dropped my oil pan and getting it welded tonight. Cant believe GM cant get an oil pan for these cars. If i would have bought a subaru i could have got an oil pan!
GM uses structural caast aluminum pans on their Ecotec series engines.
Anyone whos ever had a drain plug strip during removal on a Subaru, Honda, Mitsubishi, or Toyota stamped pan knows they are junk.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
