Opinon on the spec stage 2+ clutch
Old Jun 24, 2007 | 09:23 PM
BoostinLSJ's Avatar
ok people give me some insite in too weather i just bought the wrong clucth or not. i just bought the Spec Stage2+ clutch with the fidanza flywheel was it a good choice or what?????
Old Jun 24, 2007 | 09:26 PM
sunfirejoe's Avatar
love it had nothign but good with it
Old Jun 25, 2007 | 12:21 AM
TurboTechRacing's Avatar
Anyone who gets the SPEC "+" series have had no complaints, it is the ones that dont get the "+" series dont hold up to their expectations.
Old Jun 25, 2007 | 12:23 AM
Shortbus's Avatar
I beg to differ mine lasted like a week, and i followed the break-in period, the **** would not stop leaking, it would ingage right, or disengage sometimes, and the clutch peddle would get stuck to the floor, it didnt even hold the power, it sliped within a week. I had a spec 2+
Old Jun 25, 2007 | 01:10 AM
sunfirejoe's Avatar
short ur car was just cursed
Old Jun 25, 2007 | 01:11 AM
Shortbus's Avatar
prolly, that car was a pile.
Old Jun 25, 2007 | 01:22 AM
sunfirejoe's Avatar
cuz yah like i stated i had a 2.6 inch pulley and 60 lbs and injectors running 18 degrees of timing for about 5 months my clutch still looks mint and i run spec 2+
Old Jun 25, 2007 | 01:23 AM
Shortbus's Avatar
Mine was done in a week, my car went through 3, two stock ones and the spec 2+
Old Jun 25, 2007 | 01:24 AM
cblt12's Avatar
ya there had to be somthing chewing them up, i have a spec 2+ in my garage, i hope it will be alright!
sunfirejoe's Avatar
again cursed, or too many driving habits, but ill go with cursed
Old Jun 28, 2007 | 12:27 PM
supermantxz24's Avatar
To my knowledge its the wrong set ups (flywheel) that are messing the clutches up. the fidanza flywheel is the wrong flywheel for the spec clutches which i have been told by spec. i have been having problems with my spec stage 3+ clutch and found out that if you dont buy their flywheel they give you a self adjusting clutch which they have been having problems with it but if you buy their flywheel they give you a none adjustable clutch which will work fine. most people are having problems with these clutches because they have the wrong set up and the clutch is adjusting wrong. If you have a fidanza flywheel with a spec clutch i suggest you call spec like i did. i sent my clutch back to spec with the flywheel and From what i have been told the stage 3+ isnt the right set up with the fidanza flywheel and they couldnt moddify my flywheel for it but they could with the stage 3. maybe its the pressure plate or something. I dont know about stage2 but i recommend you call spec and ask for matt he is cool and will take the time to explain everything to you. I know some people dont have problems with their fidanza flywheel and spec clutch but all the info i got from spec and wanted to share that with everyone
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
SSLOW06
Oct 1, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
