pedals
Old Feb 20, 2006 | 01:29 AM
Rad's Avatar
Rad
pedals
well first of all i hope this is the right place to ask this question....
I have a stock 2.2L 5 spd. i am looking at replacing the pedals completely, not just have racing pedals strapped on the old ones. is this possible, and what would it run me? also is it possible to have the gas pedal moved up some, because i find it too far down to heel toe properly. this is a serious question thankyou for your replies.
Old Feb 20, 2006 | 01:36 AM
Leafy's Avatar
As far as I know there is no "magical" adjustment you can do to the gas pedal, and yes, heel and toe downshifts are pretty difficult with the current setup.
It looks to me that the pedals are just plastic covers, and there are some GMPP ones available for install.
Old Feb 20, 2006 | 01:47 AM
stotte20's Avatar
lol i think i know what a heal and toe downshit is but im going to as what is it exeatly and how do you go a about doing it and when to do it lol sorry to hijack the fourm
Old Feb 20, 2006 | 02:01 AM
italstalnprd86's Avatar
use the side of your foot, or strap a piece of wood on to the gas pedal.... there is no remedy for heel toe shifting, and it is kind of pointles unless you are on the track..... just rev the engine a little then downshift......
Old Feb 21, 2006 | 09:18 AM
freakaccident's Avatar
I disagree. Unless you live on the track and can practice everyday you will never get good at heel toe. Doing it on the street whenever you drive is the only way for some of us to practice. It becomes normal and you do it without knowing it. It becomes like breathing. Balancing the car isn't something you have to think about anymore and it allows you to concentrate on other aspects of driving.
I have not addressed this problem yet. I am going to try getting the GM pedals and only putting on the accelerator. If that isn't enough I am going to remove the rubber from the brake pedal and cover the brake pedal in non-slip tape. Not sure what I will do if that isn't enough.
Old Feb 21, 2006 | 08:46 PM
i have the gm pedals, and they are no better then stock, same exact positioning.....
Old Feb 22, 2006 | 08:08 AM
How much thickness do they add to the pedals? I am guessing that if you put all three GM pedals on nothing will change. You would have to just use the accelerator pedal.
Old Feb 22, 2006 | 12:52 PM
even with just the accelerator, since it is a whole new unit, the pedals still feel the same, with just the accelerator in...... its also a pain in the ass to get in and take out...
Old Feb 22, 2006 | 01:14 PM
Ah so they aren't just covers. Might look into getting one of the Sparco sets that bolt on. You have to drill holes in the existing pedals but they are secure. Just using the accelerator from one of those kits should help some.
Old Feb 22, 2006 | 01:16 PM
the clutch and brake is a cover......
Old Feb 23, 2006 | 02:09 PM
JapEatr's Avatar
South Central *********
i think my GM acc pedal is lower than the stock gas pedal was
it still is a good mod tho, the GM ones look like they belong in the first place
007Buff
Jun 11, 2017 03:04 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
007Buff
Sep 22, 2015 09:48 AM
calo247
Sep 8, 2015 12:29 AM
