Pirelli PZero rosso question
Hi i live in MN and we have winter here so i was wondering how these tires do in winter if i will be able to run them in winter. the tread pattern looks like it wouldnt be too bad can anyone put any info on this? thanks alot
Originally Posted by player_1
I bought Dunlop WinterSport M3's for a 16" Rim
Best winter tire you can buy and Cheaper then som of it's top competiters
my **** has pirelli p6's on it... factory
Originally Posted by codyss
Going with just a all season won't help much due to tire width and sidewall size.
Buy some steel wheels and mount a tire that is the same diameter on them but more suited for snow.
Also, steel wheels for this car are a real pain to find cheap. Tire Rack sells them for almost $50/each and that's pretty much the standard going price. Junkyards are up there too, most of the ones I have talked to want around $40/wheel because of the uncommon lug patter that the SS/SC has.
actually the steels are going to a bit more expensive because the SS has a rare bolt, bore a spacer, setup. so they won't build many.
unfortunatly we'll have to fork over the cash to get the steels.
It does suck that they're so expensive, it's looking like Tire Rack is going to be the best price. Used wheels are OK, but paying $40 a wheel for ones off of a junked car is an expensive gamble in the event that the wheels aren't true and are therefore useless...I'd rather pay the extra $10/wheel.
Obviously these tires weren't made for snow, but how badly do you guys think they will actually be? Has anyone driven an SS in any snow yet anywhere? Canadians maybe? I want to know if it's going be bad like not being able to move a foot as soon as there is an inch of snow or it won't be easy, but it's drivable type.
there are some newer cars that have the same spec. rims as the SS, but a good majority of the cars with the 5x110 bolt pattern have diferent bore and spacer spec's. I beleive that the 9-3 and the Catera are the only ones with the exact same spec as the SS.
if you look at tire rack and select a winter tire pakage you'll see that they will be chargeing $65us for each rim not $40.
are only hope for getting a deal is by doing group purchase like the one I am working on here in Toronto area.
Dude Honestly its Aug in Canada, i dont think theres snow to many places in my country right now.....but if i look closely i do see polar bears and igloos in my future.....
LSX RWD S/C conversion
Tirerack.com does list Pirelli as having 18" winter performance tires. No price that I could see as I was looking at 17" winter wheel packages. Pirelli's winter performance tire Think These will work? Or would downsizing the whole rim/tire set to say 17" or 16" be a better idea for winter?
Originally Posted by victory_red_SS
it's amazing how "Canadians" are from the land of snow and igloos....I wonder if some "Americans" even know where Alaska is?
going to a larger rim will not make your traction any better or worse for the winter, what will make the difference is how wide the tire is.
for winter traction a thiner tire is better.
plus 16" are cheaper
Iceberg
Sep 29, 2015 12:33 PM
