Please Help!
Please Help!
Ok, i need a new clutch, while the trans is out i am going to buy a light weight flywheel too! a fidanza flywheel weighs about 7.5 to 9lbs, thats 10lbs lighter than the stock flywheel. the centerforce flyflywheel weighs 5 lbs less than stock. how much do the spec, clutchmasters, and the exedy flywheel weigh??? the spec and clutchmasters are aluminum flywheels while the exedy is steel but i am told the exedy is still lightweight. but how light weight??? and what clutch should i use, a spec stage 3+, a clutchmasters stage 3, centerforce DF, DFX, or exedy hypersingle? my plan is to put a intense racing stage 5 kit on my 2007 supercharged SS with solid engine and trans mounts, and solid control arm bushings. right now my car is still stock but the clutch is slipping like a ************. i tryed driving it like the sticky thread in this forum told me to but it isn't working at all. so my next move is to replace my clutch. PLEASE HELP!
I put a fidanza flywheel in my cavalier and it literally broke to pieces taking the tranny with it... I sent it back and they gave me another... it happend again. From what i hear this is common, them breaking apart and ******* everything up in the process. I highly advise not to buy one.
Last edited by SS/SC Crazer; Jul 13, 2008 at 10:11 PM. Reason: Automerged Doublepost
so out of all the clutches you sell, would you recomend a spec, exedy, or centerforce full set up for my car? what one is the lightest, and holds the best.
