Polyurathane Tranny Insert
I know when you install just one insert you will get more vibes than if you have all of them,my question is for those that just installed the front insert,did the vibes die down after a certain amount of miles or did it remain the same?Thanks
I have heard of a few members doing it and they said it worked but i guess from your reply i guess it's a bad idea.
I want to know also.. I took mine out because the vibes were too bad. But when we installed them in my friends SS/SC his vibes were not as bad as mine. Could his torque damper have had anything to do with it?
oh and i guess i forgot the question haha.... the vibes do die down once you get some miles on them. I have 1 mount for a couple of miles to see how it was, and when i put the second mount in, the vibes smoothed out werent as rough, but were there. After maybe 1k miles they start getting quieter and less vibes, but never as quiet/smooth as stock
I bought a filled front mount a while back and ran that on my car by itself for a while. The vibes died down after a bit, but were still fairly noticable when the a/c was on. I filled my rear mount with poly and the vibes died down alot. Things felt alot better with them both filled. I would suggest picking up some poly and doing the rear yourself. It will only cost you $10.
Iceberg
Sep 29, 2015 12:33 PM
