Problem when shifting into 2nd gear.
Old Oct 23, 2008 | 11:33 AM
RA040424's Avatar
Well I've noticed a few times after being in first gear and flooring it and spinning my tires a little bit when i try to shift into second gear the car stays in first and doesnt hit second until i let off the gas aor let the rpms drop. This happened mainly at the drag strip, I'm thinking its more because of my bad launching than anything serious. anyone having this problem? Because it makes me look like a fool at the drag strip.
Old Oct 23, 2008 | 11:43 AM
Tazmanian_Dvl's Avatar
Automatic transmission I assume?
Old Oct 23, 2008 | 11:47 AM
JPizzle's Avatar
You could use the "L" & "2" gears.
Old Oct 23, 2008 | 11:58 AM
Probably won't work if he's got a problem with the valve body. Automatic transmissions determine when to shift by the line pressure and how hard you're stepping on the gas. Shifting from L to 2 wouldn't change this...
Old Oct 23, 2008 | 12:00 PM
RA040424's Avatar
No manual transmission. stage 2 ss with stage 3 pully, exhaust and headers.
Old Oct 23, 2008 | 12:01 PM
brickerenator's Avatar
clutch maybe?
Old Oct 23, 2008 | 12:05 PM
Syncros
Old Oct 23, 2008 | 12:08 PM
for as little as i know about cars
that would make sense
Old Oct 23, 2008 | 12:12 PM
RA040424's Avatar
Originally Posted by brickerenator
clutch maybe?
I Don't know, this only happens after giving about full throttle in first and shifting quickly into second, and any other time I drive the car works perfectly fine.
Old Oct 23, 2008 | 12:16 PM
D4u2s0t's Avatar
dude your clutch is slipping. this is why 2nd won't grab unless you get off the gas and let the rpms drop
/thread
Old Oct 23, 2008 | 12:24 PM
RA040424's Avatar
/thread
okay, so my clutch is slipping, now what should i do to prevent this from happening, I'm going to say launch slower and take my time then slam the gas when i hit second gear?
Old Oct 23, 2008 | 12:26 PM
New clutch. Get an Exedy...
how many miles do you have on your car?
how often do you race/go to the strip?
your clutch could just be worn out
Old Oct 23, 2008 | 12:28 PM
RA040424's Avatar
2007, 16k miles, went to the strip once. And I suck at launching, so I'm pretty sure that it's just my horrible drag racing abalities not my car.
Old Oct 23, 2008 | 12:30 PM
D4u2s0t's Avatar
you're hitting the gas too early before you're off the clutch. let the clutch all the way out before you hit the gas.
and don't spin through first. it accomplishes nothing, slows down acceleration, and puts you lower in 2nd gear so you bog.
go easier in first, and let the clutch out before you hit the gas.
Old Oct 23, 2008 | 12:32 PM
RA040424's Avatar
Thanks man, that's exactly the type of answer i was looking for. I appriciate it!
Old Oct 23, 2008 | 12:34 PM
D4u2s0t's Avatar
no problem.
Old Oct 24, 2008 | 06:46 PM
tru2nrtt777's Avatar
Syncros
QFT!
There was a mustang guy at the track here and he was running mid 16's roasting first and second gear. His friend got in it who had experience dragging and dropped it to 14 flat.
Old Oct 24, 2008 | 06:49 PM
ColeJJones's Avatar
Bannned
/thread
yep, i had the same problem at the track. irritated the **** outta me
Old Oct 24, 2008 | 06:52 PM
Omega_5's Avatar
Oh... the sound of a slipping clutch....
Welcome to the club.
Old Oct 24, 2008 | 06:59 PM
hilty003's Avatar
just to add...mine does that too sometimes. mine wont shift if i try to shift when the wheels are broken loose unless im in comp mode when the traction control is off. if i turn traction control off it works fine. and i know its not my clutch caz i only got 3,000 on the car so. see what you think.
Old Oct 24, 2008 | 07:47 PM
Depending on driving habits and driving style/skill a clutch can go in less then 3000 miles.
Old Oct 24, 2008 | 07:49 PM
hilty003's Avatar
i mean i havent been hard on it at all really. 300 sum odd miles were from the dealer driving it in from another state too. its still real strong, id know if it was slipping i promise haha
Old Oct 24, 2008 | 08:07 PM
The stock clutches on these cars are effed up right from the get go! Like previously stated you may be hittin the gas before the clutch is completely out. I found the clutch grabs better the faster you let it out.
Old Oct 24, 2008 | 08:19 PM
hilty003's Avatar
thats probably what i was doin with the car in regular mode yea your right. but thats why im saying it worked in comp mode caz you dont have to lift the gas. so i just thought he might be doin the same thing i was. and id probably agree about the faster the better its pretty touchy and jerky if you try to be too slow with it.
