Problem when shifting into 2nd gear.
Old Oct 24, 2008 | 10:27 PM
Tazmanian_Dvl's Avatar
I more or less pop the clutch every shift. I have 40K on my car and my clutch doesn't slip on bit.
Old Oct 25, 2008 | 07:36 PM
Maven's Avatar
Originally Posted by hilty003
just to add...mine does that too sometimes. mine wont shift if i try to shift when the wheels are broken loose.
Um, youre not SUPPOSED to shift when the wheels are broken loose. This is one of the exact behaviors that kills F35s
Old Oct 25, 2008 | 08:36 PM
hilty003's Avatar
im just sayin if the fronts are still doin there slip grab slip grab stuff that 1st gear often does when you launch a lil too hard, im gonna shift when its about to redline. im pretty sure this isnt gonna kill it.
Old Oct 25, 2008 | 08:41 PM
JimzSS's Avatar
I personally thi nk the stock friction material is good. I also believe the pressure plate and lazy a$$ hyd. throw out suck causes the slippage.
Old Oct 25, 2008 | 09:07 PM
Maven's Avatar
Yup, thats what does it. your not supposed to let it do the whole slip grab slip grab slip overrev deal.
Old Oct 25, 2008 | 09:16 PM
D4u2s0t's Avatar
U have to look at your speed not rpms. Even though the rpms are maxxed if you're spinning you're most likely not really at the top of the gear
Old Oct 25, 2008 | 09:25 PM
hilty003's Avatar
isnt it bad to hold it at redline even if you not at what would be the max speed for that gear? ...i would think u would still wanna shift even if your not up to that speed.
Old Oct 25, 2008 | 09:29 PM
eurochevy's Avatar
Originally Posted by robertwhamm
Well I've noticed a few times after being in first gear and flooring it and spinning my tires a little bit when i try to shift into second gear the car stays in first and doesnt hit second until i let off the gas aor let the rpms drop. This happened mainly at the drag strip, I'm thinking its more because of my bad launching than anything serious. anyone having this problem? Because it makes me look like a fool at the drag strip.
you should be letting off the gas to shift into 2nd any way ..your not a T/c with the no-lift shift .....
Old Oct 25, 2008 | 09:45 PM
hilty003's Avatar
thats what im sayin...at least i feel like im not way off base here now
Old Oct 25, 2008 | 10:59 PM
D4u2s0t's Avatar
the point is you don't want to be spinning, and if you're not spinning you won't have that issue.
Old Oct 25, 2008 | 11:02 PM
  #36
hilty003's Avatar
hahaha agreed
Fearedbynone
Apr 14, 2016 03:25 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
