Problems shifting quick with a hypersingle
Ok so the exedy has been great, however occasionally when WOT, shifting near redline (Not NLSing) i will get a grinding type noise that i DO NOT feel in the shifter. This happens into 2nd and 3rd on "quick shifts that I never had problems with on stock clutch. Under all other conditions, the shifts are as crisp as brand new, if not better. I have a hard time thinking is synchros because way back when i remember grinding into 5th while cruising and i could feel it in the shifter.
Now ive got some variables since i was stock
Exedy HyperSingle... about 1600 miles
OTTP Stage 2 mounts? Anyone else experience shifting issues with these?
I have adjusted The Shifter position already, still does the noise
Clutch install learn was done one the Stock/OEM ECU, Car is operating on Tuned 2nd ECU
If anyone has any input, so i can narrow it down before i take it back to the installer?
Thanks
Thanks
