Quick question for u 400+ whp lnf's
So as the title states, I'm curious to know which transmission u high hp lnf's r running? Reason y I'm asking is because I had Powell's 4.45 on my fully bolted n tuned zfr on 91 octane n it blew 3rd gear after about 8 months or so. I'm currently stuck on deciding what to do. Should I try to see if I can reuse the 4.45 gear set and put that into another used tranny or should I think about going the 6 speed f40 route from ZZP? I really dont want to go that route because its ridiculous how much its going to cost with shipping n labor. I don't see it being worth all the money on a car that depreciates like there's no tomorrow. Anyways, I've heard that there are a few high hp lnf guys running the f23 tranny, true? If so, what was done to it? Any mods or just bolted it right up? How is it doing and what is your set-up/whp? Thanks!
Term2 tuned me. This is my first time hearing about the f23 tranny being used on lnf's as well. If it matters, Term was actually the one who told me about it... If the f23 can really be used and can hold the power reliably then I'd rather go that route.
I was running my Stock LNF LSD 3.82 transmission and stock clutch when I was on the ZFR. It started slipping a little bit but held the power.
I was on a 27 psi 91 tune, so I would assume around 400 whp give or take. then i switched to an e30 30 psi ZFR tune. and that was when my clutch started to slip.
You're still on stock tranny n clutch? Wow, u must have a nice boost ramp to last that long. Especially on the e blend... Interesting... I also have s1 cams, injectors, n valve springs waiting to go in but at this rate the tranny can't even handle my current set-up on 91 let alone an e-blend with cams...
fwd ftl....
Car is 100% stock now.
Yea, same here. Only difference is I don't have the boost ramp. Lol which can explain the tranny failing.
Lol yea, I'll admit I probably need a driver mod but I highly doubt that was the MAIN cause. I always rev match when I down shift, and when coming to a stop I also down shift to help the tranny n brakes while using the engine to help slow the car down. I also don't go out cruising much anymore either so there's not that much wear and tear from pushing it hard. I never go wot under 3.5k rpm, only 4k or above. Then one day I decide to do a little pull after running some errands to enjoy the power again and bam, 3rd gear takes a **** on me. I think I'm just bad luck. Lol
Tranny problems cost so much if mine went I'd seriously consider selling or trading in the car. Or put it in a garage and slowly learn how to replace it yourself or with a buddy.
If you go the 6speed route you will have to keep this car for quite some years to make it worth while. Are you prepared to marry this cobalt? lol.
I hear you on re-sell value. Cobalt owners are forced to stay by their decision or take a big hit when selling. My car's worth like 1/3rd of what I paid for it 5 years ago. Thank goodness I haven't had a problem off warranty, and that the problems happened and were covered under warranty.
Powell said there is no guarantee what his transmission can hold.
Some guys make **** tons of power on stock transmissions and have no problems, others have built 6 speeds and 4.45 5 speeds and break 3rd gear.
I don't want to try it and have that fail on me too. That will just cost me more money on repairs again so that's y I started this thread to see if anyone on here has tried it yet and what advice they might have.
Say what!?! Even the built 6 speeds break? Wtf!!!! I'm definitely not going that route then. Lol with my luck, I'm better off just boost ramping the zfr and calling it a day. Lol I'll keep the car until I finish school, get my job upgrade, then if I want to stay with gm then I'll go for a used 09-11 cts-v. If not then I'm definitely going to consider the Germans. Lol the cts-v and the vette are the only gm cars left that I would even consider owning from gm.
Just cause you buy a built transmission it doesn't mean you can beat the **** out of it and it wont break. There is no guarantee with modding these cars. the F35 sucks, even with 4.45 driver mod is the number 1 thing you can do to prevent your transmission blowing up
yeah dude
You can always go back to stock or near stock. No shame in that.
I dumped like 8k into my last car. Regret it too. That's why im happy to settle with $1000 spent on the SSTC (tune,intake,downpipe,VTABOV).
Ever think of buying a Motorbike to curb your need for speed?
I work in EMS and see too many "accidents". I value my life too much to put my life into other careless drivers hands. Lol with a car, ur chances of survival is higher. I guess I'm just a wuss.
