Quick question for u 400+ whp lnf's
I am pretty sure you still use the LSJ/LNF FW and Clutch
except you just need the f23 clutch pipe and bleeder block. The line from the clutch master to the bleeder block is confirmed to be the same in the f23 and f35
Things you need
-You can use the lsj clutch/flywheel, you will need the trans spacer
-f23 axles
-f23 shift cables
-f23 front trans mount
-Modified lsj thermostat housing to clear the shifter cables
-f23 line from the clutch master cylinder to the f23 slave
-f23 slave cylinder
-f23 axles
-f23 shift cables
-f23 slave cylinder
hope mine don't break. on 27psi with meth got a good boost ramp and don't give er till past 3krpm have done a bunch of hard pulls. also have torque tuned down. most of the time I drive normal though. not to hard driving unless tuning.
F23's are getrag transmissions, with shorter gear ratio. So they hold power
F35's are Saab transmissions that are based on a 25 year old design. Coupled with the LNF's 3.82 gear ratio causes issues with high torque, high horsepower cars. I notice that more people blow up their tranmissions when they use six-puck clutches.
How are you guys breaking 4.45s..... I've had my 4.05 swap for 20k miles now and the block let go before the tranny, and still going strong.
Im curious as to the internal design of the f23 since GM rates the torque as NM. Wonder why they rated it low.
F23 = 230NM cap
F35 = 350NM cap
F23 = 230NM cap
F35 = 350NM cap
broken f40? this is the first im hearing of this...what broke? im betting it was just syncro related which would lead to my next question...What clutch and flywheel was used?
patooyee
Oct 1, 2015 01:07 PM
