racing transmission
Old May 8, 2008 | 03:10 AM
chevy cobalt 08's Avatar
Originally Posted by CSuttie
im not talking about dumping the clutch. im talking about starting the car with first gear engaged. without touching the clutch.
thats impossible cause the car will not start unless the clutch is engaged
Old May 8, 2008 | 03:15 AM
CSuttie's Avatar
hence the fact that i could cause my clutch delaminated.
no clutch plus clutch pedal = starting my car in gear
and you dont have to give any gas without stalling?
Old May 8, 2008 | 03:17 AM
CSuttie's Avatar
correct.
hmm and the gears dont grind if you shift without the clutch??
Old May 8, 2008 | 03:27 AM
CSuttie's Avatar
if you know how to double clutch properly, you wont grind your gears. there are particular rpms at particular speeds when you can simply slide the shifter into gear without incident. and theres little tricks that make it easier. it still isnt all that great for the tranny, but if you gotta do it, you gotta do it. you may notice that you can pull out of gear w/o using the clutch, basically when shifting up, u pull out of gear, and wait for the right rpm for the next gear to line up with ur speed (rev matching) and then it just slides in no problem, with down shifts, you pull out of gear, rev up to the match point, and slide in... it really isnt hard with a little practice.
*EDIT* my dad once told me he did this with his chevelle, just cause he could... lol
Old May 8, 2008 | 03:33 AM
yeahh i don't think i wanna risk effing up my tranny i'd try on a rental or something tho! hahaha
Old May 8, 2008 | 03:34 AM
CSuttie's Avatar
haha, nice.
Old May 8, 2008 | 03:36 AM
question.. can sliding out of any gear into neutral cause any damage at all? like say by accident or something? i assume no but just wanna double check
Old May 8, 2008 | 03:38 AM
CSuttie's Avatar
im not going to say its good for your tranny, but i wouldnt call roadside if you did it.
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
Sep 27, 2015 08:53 PM
