Rack Spacers changed Steering Rack Angle
Old Feb 14, 2011 | 02:22 PM
skiermann1's Avatar
After months of waiting for them to arrive, I finally installed my steering rack spacers from OTTP today. They recently re-designed them and I noticed that some spacers have an inset for the rack bushings to sit in but these are flat on top and bottom. When I installed them the rack was angled toward the front of the car, which straightened out somewhat when I torqued them, but it is still sitting a little forward and there is a slight gap between the bolts and the rack. I was wondering if anyone else has used these and had a similar outcome and if there were any problems that resulted from this. It seems to drive fine but I'm not sure if a problem will develop over time or they will loosen out.
Old Feb 14, 2011 | 02:26 PM
skiermann1's Avatar
Just did some reading and saw that some people had to grind down the rear trans mount. I did see that it was awful close, but didnt think it was touching. Maybe it is and that's affecting the angle but either way the bushings don't fit in the spacers right so any suggestions would be great.
Old Feb 15, 2011 | 12:31 AM
ronn's Avatar
Just get these from Turbo Tech Racing...$20
Old Feb 15, 2011 | 08:57 AM
skiermann1's Avatar
well looking back now I definitely would have gone with TTR but I just went for a drive and hear clicking in the front of the car and plan to remove the spacers as soon as it warms up a little outside. Now I have two nicely machined spacers for use on anything but my steering rack.
Old Feb 16, 2011 | 07:57 AM
Josh@ottp's Avatar
If you have a gap you either installed something wrong or the steering rack is hitting the mounts. Eitehr way don't drive it till you fix it.
Old Feb 16, 2011 | 08:01 AM
Something isnt right with the install. I have the same set from ottp with no issues. had them installed maybe 6-7k miles and counting.
The ones from TTR hit my trans mount and i ended up selling them and going with a slightly thinner OTTP spacers and had no problems.
Old Feb 16, 2011 | 08:11 AM
09whteSSpssssh's Avatar
Do you have aftermarket tranny mounts? I had trouble as well when I was on the stock mounts
Old Feb 16, 2011 | 08:29 AM
skiermann1's Avatar
I took them out yesterday - I think the rack might have been hitting the mount but the car drives fine without them. I don't mean to be so pessimistic but I just thought they were a direct fit as there's no instruction for grinding down tranny mounts.
Old Feb 16, 2011 | 10:10 AM
Mine are installed with stock mounts and poly inserts
Old Feb 16, 2011 | 11:34 AM
06SS ALL DAY's Avatar
does this fix axle bind?
Old Feb 16, 2011 | 11:43 AM
im on h&rs and havent had axle bind
Old Feb 16, 2011 | 11:47 AM
northvibe's Avatar
what springs are you using? did you ask them to get you the right spacers for the right spring? I have pedders with spacers for just them and they worked fantastic.
Old Feb 16, 2011 | 11:55 AM
i asked does this fix axle bind lol
Old Feb 16, 2011 | 12:34 PM
skiermann1's Avatar
i have stock tranny mounts, lowered 2"front, 2.5" rear and ordered the spacers for cars lowered 2-2.5". I have an LS with drop zone springs. btw the springs are great for everyday driving but not so much for performance - very soft
Old Feb 16, 2011 | 01:40 PM
Yes and people say h&rs give axle bind hence my answer
Old Feb 16, 2011 | 01:51 PM
Hodz's Avatar
Dont steering rack spacers only fix bump steer?
Old Feb 16, 2011 | 02:23 PM
northvibe's Avatar
well they get the suspension, knuckles etc. back to "normal" level, instead of being at a odd angle because of lower springs. Which in turn does fix bump steer.
Old Feb 18, 2011 | 03:12 PM
importkiller's Avatar
I have pedder springs OTTP transmission mounts and rack spacers with zero issues in mounting the rack spacers (except I was a retard and took both bolts off at the same time and had to go get an alignment because i messed up my center on my steering wheel. )
Solaris99
28
Mar 15, 2017 01:22 PM
TedSS
26
Oct 10, 2015 04:30 PM
importkiller
Sep 30, 2015 07:18 PM
goaliemo
Sep 28, 2015 01:37 PM
