Reduced engine power PLEASE HELP!!!
Old Nov 19, 2010 | 12:08 PM
ARAB's Avatar
Ok, so i drive a 06 cobalt ss and i have been getting the dreaded reduce power signal. the codes are p0102 MAF low input, p0036 o2 sensor heater control, p0030, p0135 o2 sensor heater circuit malfunction, p0141 o2 sensor heater circuit malfunction, p0443, p0135, p0102, p0068, p0135, p0141, p0443. some are repeats ireplaced both o2 sensors, mass airflow and MAP sensor. I also cleaned the purge valve. I have seen 4 certified techs and no one can tell me whats wrong i need help!!!
Old Nov 19, 2010 | 12:13 PM
Chevycobaltss3's Avatar
Look at ure.02 ensor wiring make sure its not.melted.to.ure exaust. Make sure ure wiring is good frm pcm to connectors. Clean maf. If this don't help clear the codes, take power from the car. For 10mins. Restart the car. U should get the.code.quickly, start from ure first.codes then diag. From there.
Old Nov 19, 2010 | 12:42 PM
ARAB's Avatar
thanks for the info im headed to work now ill have to check that out before it gets dark tonite ill post up after its done.
Old Nov 19, 2010 | 04:19 PM
K man if u need more hekp feel free to.text me. 270-505-3212 or call
Old Dec 17, 2010 | 10:54 AM
ARAB's Avatar
thanks for the help man ive been working 8hrs 7 days a week but finally got some time to check things out and sure enough it was exactly what you explained
Old Dec 17, 2010 | 11:45 AM
Good deal glad all is good now.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
