removing axle seal question
I wouldn't remove that. I would just use a small pry bar and pop it out. And keep working at it. Apply a lil heat to the seal. They are a bitch to get out. And they're not the easiest to put back in either. You have to get it seated perfect, if it starts to go in Crooked you will need a new seal. When I did my trans they where stubborn.
Use a large socket, smaller than the size of the hole in the casting, about the size of the steel part of the seal. Tap on the socket with the hammer. This is how I do it. Works well.
can you please tell me axle seal part number and where you got it from please..... I've been looking forever and cant seem to find it...Mines an 05 SS so it should be same as your seal, correct?
Go to RockAuto Auto Parts pic your car and year and model. And it's under manual trans/ out put shaft seal. It's like 5$ and some change.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
