Shifter cable/Roll pin ???
Old 11-03-2010, 06:09 PM
blackboltss's Avatar
I have an 06 SS/SC almots 90,000 miles. I have been looking on the forum and I cant fine an anwser. My 2ed, 4th, and rev gears are gone. I was shifting kinda hard into 2ed gear and it went lemp and just reved. 1st, 3ed, and 5th are all fine. I have seen people say its the Shift linkage, Shift cable and roll pin. Which one is it? I brought it to the dealership they didnt even look at it and said shift cable. I really dont want to spend $300 on a new shifter cable if its only a roll pin. Thanks for any help
Old 11-03-2010, 06:11 PM
CleverOne's Avatar
There is a how too in the how too section on how to change the roll pin, i dont even think its a dollar part. I would just change the roll pin and see if it fixes it.
Old 11-03-2010, 06:39 PM
1fastSSBalt's Avatar
Ya Sounds like Roll pin. I had mine break and I lost 1st 2nd 4th and then every gear in a matter of minutes lol wasnt even driving it hard.
Old 11-03-2010, 06:47 PM
Lifter's Avatar
I doubt it's a roll pin. I lost my second, fourth, and reverse and it was a broken shifter cable.
Right underneath the fuse box, the shifter cables connect. Check to see if it has play in it, or a piece came loose there. It's not easy to move back and forth with your hand, and if it does, probably need to replace them.
Old 11-03-2010, 06:55 PM
Im going to try the Roll pin first... its only a couple of bucks.. if that does not work i'll get a new shifter Cable. anyone know where I can get one for cheap? Idc if its used or new. Part number 10383794. Dealership told me $161.75
Old 11-03-2010, 06:58 PM
Lifter's Avatar
Ebay and google are your best friend.
Cobalt SS Manual Transmission Shifter Cable Ion Red Lin: eBay Motors (item 260678939078 end time Nov-15-10 08:59:14 PST)
Old 11-03-2010, 07:32 PM
Sweet. Thanks lifter
Old 03-25-2014, 12:37 PM
kobe77's Avatar
im havig the same issue now. lost 4th 3rd 2nd grabbed first then nothing.
Old 03-25-2014, 05:19 PM
06blackbalt's Avatar
Op It's your shift cable I've broken 3 at the track
Check out ZZP they have the updated one in stock
Old 03-25-2014, 08:28 PM
mrbelvedere's Avatar
look at the date
Old 03-25-2014, 08:29 PM
BlackielawlessSS's Avatar
At least he used the search engine mr b
Old 10-17-2016, 09:38 PM
315SS's Avatar
While making passes this past Saturday, I lost 1-3-5, re adjusted cable clamp then lost rest of them.
My pass side cable when trying to shift in and out of gear must be over extending or something, is hitting my drivers side top transmission mount.
Any input on what it may be before I order parts and tear apart? Pins cables?
Spanky's Monkey
03-07-2016 06:06 PM
biniecki
10-25-2015 02:23 PM
dennis69
10-20-2015 07:39 AM
HEATON
10-16-2015 07:21 PM
Cptnslo
09-24-2015 09:32 AM
Quick Reply: Shifter cable/Roll pin ???
