Shifting and linkage
Old Sep 22, 2015 | 09:34 AM
007Buff's Avatar
First off I use my 2010 lnf as a daily driver, don't race it and certainly don't NLS. About 3 months ago I was getting onto the freeway and I was wot in 2nd and when I shifted to 3rd it popped and I had nothing. I pulled my shifter console apart and the linkage that connects on the right side of the shifter had broken off. So I had to order in a whole new shift kit and housing. Now 3 months later my shifting is getting more and more ruff and if I'm wot in 2nd and try to go 3rd it like wont go in, I have to let of the pedal and then push it in, and I'm always worried it is going to pop again because it is so forced. So I guess I don't know what to do? Is it linkage problems, clutch, trans? Any advice is appreciated, btw only have 41k miles on it
Old Jan 19, 2016 | 09:15 AM
007Buff's Avatar
Bump...
Old Jan 19, 2016 | 10:25 AM
blueLNFftw's Avatar
Your throw out bearing/slave is dying.
When you push the clutch the TOB is not fully extending to engage the clutch.
Old Jan 19, 2016 | 03:44 PM
footballplaya3k's Avatar
Do you have a cable clamp? Those prevent the disconnect problem on 2/3 shifts.
Old Jan 19, 2016 | 07:57 PM
007Buff's Avatar
Sorry not familiar with that, everything is stock, when it popped the first time it broke off on the shifter ball on the right side where the linkage attaches, how/where do I get the cable clamp?
Old Jan 19, 2016 | 09:42 PM
firehawk618's Avatar
Clamp linked below.
Easy test to see if your clutch hydraulic system is failing.
When not moving can you shift in and out of gears with no effort?
If you have to push harder than normal that means your clutch isn't disengaging all the way and that will certainly cause shifting issues when driving.
This clamp or one similar to it will solve the cable popping off the shift lever problem.
OTTP Cable Clamp for Cobalt SS SC/TC
Old Jun 11, 2017 | 03:04 PM
jgerma01's Avatar
I just noticed an issue with my shifter today. When i take it out of gear normally its springs back to the middle now it just stays to the left if for example i take it out of 1st to neutral. Also notice its very hsrd to push to the right like to shift into 5th.
Any ideas?
RaginChopsuey
Oct 27, 2015 01:27 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
007Buff
Sep 22, 2015 09:48 AM
jcalvin1126
Sep 11, 2015 10:24 AM
