shifting problem
Old Jun 23, 2009 | 09:41 PM
fastscion's Avatar
shifting problem
I've a 2006 Cobalt SS S/C
I changed the clutch for a centerforce kit (pressure plate disk and flywheel with the gm throw out bearing) after installing the kit we got a oil leakage problem (dot 3 brake fluid)
that appeared to come out of the transmission. the mechanic checked the issue and fixed the problem which was the connection link between the tranny and the brake fluid reservoir wasn't well connected as he told me
after fixing this now i'm experiencing rough shifting which wasn't the case in the beginning
any help please thanks in advance
Old Jun 23, 2009 | 09:46 PM
YellowRocketSS's Avatar
Try bleeding the system more. Sounds like your air bound
Old Jun 11, 2010 | 06:54 PM
fastscion's Avatar
does the clutch system (pressure plate and disk )of the turbocharged cobalts fits the supercharged cobalt?
Old Jun 11, 2010 | 07:01 PM
Iam Broke's Avatar
I believe the GMPP LSJ clutch is the LNF unit. If someone can verify this, I have a used one, flywheel, disc, slave cyl & pressure plate I'll sell reasonable. $350 shipped complete to conti US. 20K miles on it, just wouldn't hold my torque anymore.
Old Jun 11, 2010 | 07:23 PM
fastscion's Avatar
that's my problem i changed like 4 clutch sytem already 2 was from SPEC stage 2+ everything new Flywheel clutch+pressureplate and throw out bearing had problem shifting on high revolution wasn't worth the money!
went to try a combination of stock new pressure plate with new spec clutch plate didn't function well
went to centerforce complete new set did it for some time but isn't doing it well anymore
and i want to fix this issue for once and for all now
Old Aug 22, 2010 | 05:23 PM
fastscion's Avatar
fixed without changing the clutch system
thanks for all replies!!!
Old Aug 22, 2010 | 06:21 PM
Iam Broke's Avatar
What was the solution? Vacuum bleed it?
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
