Short throw
Old Oct 17, 2006 | 12:55 PM
jester's Avatar
Short throw
I dont know to much about the different shifters, but I was wondering if you could notice that much of a difference between stock and aftermarket. I am thinking about getting one, but also am considering getting mounts. Im between the two right now but cant afford both at the moment.
Old Oct 17, 2006 | 11:30 PM
RedSSBaltSC's Avatar
I have noticed a bit of difference with my B&M. It was a bit of a pain to install. I had to cut the stock one in half to remove the housing for the new one. Also, in order to be able to get into 5th without lifting the reverse lockout I had to hack and the housing. Not too bad, but I've installed MUCH easier. PM me for more specific
Old Oct 17, 2006 | 11:37 PM
Boosted_SS's Avatar
the Hurst shifter looks ALOT better then the B&M IMO i don't think it's out yet though
Old Oct 17, 2006 | 11:48 PM
uthinkimodd's Avatar
you wont notice much throw change.... and if you have to cut anythign you're doing somthing wrong.
Old Oct 18, 2006 | 08:41 PM
You have to cut with the B&M, and if you don't then you'll have to lift the reverse lockout just to get into 5th.
Old Oct 18, 2006 | 08:45 PM
you shouldn't have to cut.
Old Oct 18, 2006 | 08:57 PM
Did you install one?
Old Oct 18, 2006 | 09:01 PM
yes I've installed 4
Old Oct 18, 2006 | 09:03 PM
JohnnySasakiMGS's Avatar
I have the 2.4 ss. I installed my TWM ST and i DID have to trim a little bit of the plastic off. Its not anything major, however It may be different for the supercharged model. Installation is sort of tedious and can be confusing. And yes you can most definitley feel a difference. 1st to neutral before installation is like 1st to 2nd after its installed. You'll love it. But go with hurst it looks alot better.
Old Oct 18, 2006 | 09:08 PM
cobaltss2.4L's Avatar
would it be possible to turn the stock shifter in a 2.4L to a short throw? i like the shift knob on it but i think it would look cooler if it was shorter
Old Oct 18, 2006 | 09:17 PM
Well lets see. No. You could cut the shifter to make it "look" shorter. <-- Which is an extreme ricer move... But you won't get a shorter throw. You'll just get a crappy looking destroyed PLASTIC shift knob. Just get the TWM shifter with the A6 leopard or the M1 abrahms knob. Also if you go to www.twmperformance.com you can see a diagram of how a short throw works.
Old Oct 18, 2006 | 09:40 PM
i'm not into racing my car. if i wanted to race it i would of bought the 2.0 s/c. i'm into making my car look nice.
Old Oct 18, 2006 | 10:59 PM
jester's Avatar
Cool thanks for the info guys, looks like im going for the mounts.
Old Oct 19, 2006 | 07:57 AM
Same here but a little functionality with those good looks is better. I suppose you could cut the steel a little shorter but I'm just dont think its a great idea.. It might look horrible.
Old Nov 29, 2006 | 10:38 PM
DoMiStIc_RuSh_06's Avatar
I'm new here! Which short throw gives the best bang for it's buck. Which one is of better quality!
Old Nov 29, 2006 | 10:45 PM
diablo2007's Avatar
i cut mine and ill tell you that its nothing like a short throw shifter but you can jerk it a little harder without having to worry about breaking something which makes for a faster shift
Old Nov 29, 2006 | 11:15 PM
Boosted_SS's Avatar
HURST FTW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 30, 2006 | 01:18 AM
jimbos'ss's Avatar
dude i'm def gonna have to get the m1 abrams shift knob now i'm an m1 abrams crewmember in the army. that so rocks
Old Nov 30, 2006 | 01:28 PM
Thanks! I just went and ordered my hurst today.
Old Nov 30, 2006 | 01:33 PM
R&C_rallySS's Avatar
I thought with one of the short throws you can use the stock shift knob. I almost 100% sure I read that with one of the brands. B&M maybe.
Old Nov 30, 2006 | 03:12 PM
thedubsack85's Avatar
mount will give you mich nicer shifting. cause theres no engine movement. and as far as a short throw goes. b and m supply's you with a new knob. so does the hurst. the b and m comes with new metal bushing for uinder the shifter try. again making it stiffer. an as far as throw is concerned. on the b and m i noticed like a 40% reduction in throw. even says it on the box.
06MetallicBalt
Jul 20, 2025 08:47 PM
Cptnslo
Sep 24, 2015 09:32 AM
Dustonian131
Sep 23, 2015 08:03 PM
ashalle2
Sep 16, 2015 10:36 PM
SS_2009_TC
Sep 11, 2015 05:41 PM
