Slave Cyl. Leaking
Old Apr 14, 2011 | 01:24 PM
hunter19707's Avatar
Slave Cyl. Leaking
I installed a six puck clutch in Jan. and found the slave cyl. to be leaking from the seal, replaced it, and a day later it is leaking again. Any ideas on what the problem could be? Could the clutch be off balance somehow causing the leak around the seal? Loose fitting after the install? Man, this sucks. I may just put the stock back in.
Old Apr 14, 2011 | 01:34 PM
Iam Broke's Avatar
GM LNF slave or another lesser brand?
Old Apr 14, 2011 | 02:00 PM
GM this time.
Old Apr 14, 2011 | 02:42 PM
Iam Broke's Avatar
After I had my clutch replaced over a year ago, the fluid weeped out of the bellhousing for a few days after the disassemble/reassemble. I was afraid I had a leak then, but it turned out to be whatever accumulated during the process.
Are you loosing level in the master cyl?
Have you opened it up to see if the slave is leaking this time?
Could be the flex pipe?
Green LNF slave or older weaker LSJ?
Just some thoughts.
Old Apr 14, 2011 | 03:16 PM
Original slave with six puck was green, the slave installed yesterday was gm black(I think black). It was done at the dealer. Master cyl. lost half it's fluid. Spot on the ground about the size of a coffee saucer. I could hear a rattling sound when the pedal was pressed in.(faint sound, but noticeable). Maybe slave is being overextended?
Have not looked at it yet.
Last edited by hunter19707; Apr 14, 2011 at 03:16 PM. Reason: Automerged Doublepost
Old Apr 14, 2011 | 03:28 PM
Chevycobaltss3's Avatar
Do not use the zzp adjustable to far extended......... Clutch wise i dont see it being the issue since it has to be flat and aligned with the friction disc and pressure plate. Ure t.b is warrantied. I am assuming u got a bad t
b again.........
Old Apr 14, 2011 | 03:33 PM
Iam Broke's Avatar
The LNF one is green, they used the weaker LSJ one IIRC.
Old Apr 14, 2011 | 04:00 PM
Are you sure? I believe the stock slave that was removed was black when I got my parts back after install.
Old Apr 14, 2011 | 05:21 PM
Crate Engine Depot shows the lsj as green and the lnf black. Are there pics correct? I'm getting confused.
Old Apr 14, 2011 | 08:30 PM
Iam Broke's Avatar
No, I'm not sure, sorry. I'd have to go in the attic and see what I took out of mine. I'm old and a feeb.
You and CED are prob correct.
Old Apr 14, 2011 | 09:08 PM
Yeah, I'm getting pretty old myself. I'm at work till 11:30, so I'll try and look inside the bell housing and see where the leak is coming from tomorrow.
Old Apr 15, 2011 | 08:08 AM
Iam Broke's Avatar
Found this posted by quikredline...
"TC has more stroke no green bootie like lsj and costs less. works very well"
so black is the correct LNF one. I believe John Powell. lol.
Old Apr 15, 2011 | 09:10 AM
ctn2mb's Avatar
The LNF one I got from GM is green...
Old Apr 15, 2011 | 09:21 AM
Iam Broke's Avatar
Guess we need the part numbers for research then. I'll climb up in the attic Sat. and look at my original OEM one.
Old Apr 17, 2011 | 12:58 PM
mongorat427's Avatar
The new LNF 3.82 trans I have has a green one. I have an old LSJ trans downstairs Ill look at it. Well they both have green ones so I would guess that the black one is the upgraded one.
Old Apr 17, 2011 | 01:35 PM
Heres a pic of the newer LNF bearing
2.0 LNF Clutch Bearing - Cylinder 24242805
Old Apr 17, 2011 | 01:45 PM
Clutch Master cylinder, cobalt
05-10 $161.85 $95.94
Clutch - Hydraulic system - Master cylinder
Old Apr 17, 2011 | 01:48 PM
This is the one that was just installed. I am getting a leak from it not even 24 hours after installation. I will find out tomorrow what the deal is, I hope. This problem is getting old, just want it to go away.
Old Apr 17, 2011 | 05:07 PM
I just remembered I took apart that 2009 F35 about a month ago that had a cracked case. It had the black one in it and the part number is stamped right on it. This one looks to be intact with no fluid on it. I wouldnt use it anyhow. 24242805 part number. 2009 must be the first year they used that one.
Old Apr 17, 2011 | 09:38 PM
SSPainter's Avatar
I replaced my clutch over winter, and replaced my slave, and it leaked, i did everything by the book. turned out it was a bad one from GM and he said its happened before. So I got a new one and everything worked fine the second time.
Old Apr 17, 2011 | 10:12 PM
Wonder what the odds are of it happening twice in a row? I guess anything is possible with my luck!
Old Apr 24, 2011 | 11:31 AM
2.0 LNF Clutch Bearing - Cylinder 24242805 Crate Engine Depot Price
SKU: 24242805
RETAIL: $97.67
YOUR PRICE: $73.24
GM Parts Direct Cost less
Mechanical Catalog
Item Number MSRP Price
24242805 $97.67 $57.86
Clutch - Hydraulic system - Slave cylinder
Slave cylinder, cobalt, 2.0l 2008 - 2010
Add to Cart Contact Us
OEM Catalog
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
n20saturn
Sep 30, 2015 12:26 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
