Splitting Trans from Bellhousing
Old 12-02-2006, 03:15 PM
06REDSS/SC's Avatar
Anyone know how to Split the Transmission from the Bellhousing. I have taken every bolt holding the two together out, and tryed prying it apart i moves approx. 1/4 inch, then when i took the pry bar out it snaps back together like there is something inside holding it together still.
I am trying to replace the Bellhousing, because it is cracked where it bolts to the front tranny mount. I already have the new bellhousing.
Old 12-02-2006, 06:00 PM
Malaclypse's Avatar
Did you make sure to unbolt and remove the intermediate axle shaft that runs along the back of the block?
Other than that, get a bigger prybar, or start wiggling and pulling at the same time. Just be ready to catch when it breaks loose. As long as nothing is still connected it should just fall out.
Old 12-02-2006, 06:10 PM
06blackg85ss's Avatar
you need to pull the gears off the end of thee tranny... if you take the cap off (towards drivers side) there are I think three gears you need to pull to take the casing apart...
Old 12-02-2006, 07:05 PM
06REDSS/SC's Avatar
I pulled that cap off of there, but i didn't see any way of taking those gears off.
Old 12-03-2006, 08:37 AM
denniss's Avatar
Here is the GM procedure for a Getrag 5 speed. That is whats in a SS/SC right?
I hope this help you.
Dennis
Document ID# 1499764
2006 Chevrolet Cobalt
Transmission Replacement
Removal Procedure
Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection .
Remove the positive battery post from the underhood junction block (2).
Disconnect the positive cables from the underhood junction block (1).
Disconnect the surge tank inlet hose from the surge tank.
Remove the underhood junction block bracket nuts (1, 2).
Loosen the underhood junction block bracket bolt (3).
Disconnect the front wiring harness from the underhood junction block bracket.
Reposition the underhood junction block bracket aside.
Disconnect the hydraulic clutch hose from the clutch actuator cylinder.
Install the engine support fixture. Refer to Engine Support Fixture .
Secure the cooling module to the upper body structure.
Remove the upper transmission to mount bolts.
Remove the upper transmission to engine bolt.
Remove the frame. Refer to Frame Replacement .
Drain the transaxle. Refer to Transmission Fluid Replacement .
Disconnect the drive axles from the transmission and secure out of the way. Refer to Wheel Drive Shaft Replacement .
Remove the starter. Refer to Starter Motor Replacement .
Disconnect the shift cables from the transmission. Refer to Shift Cable Replacement .
Disconnect the backup lamp switch harness connector (1).
Disconnect the vehicle speed sensor (2).
Lower the vehicle.
Use the engine support fixture rear hook to lower the powertrain enough to allow clearance between the side rail and powertrain.
Raise the vehicle. Refer to Lifting and Jacking the Vehicle .
Use a transmission jack to secure the transmission, and remove the transmission to engine bolts.
Remove the transmission from the vehicle.
Remove the front transmission mount from the transmission. Refer to Transmission Front Mount Replacement .
Remove the rear transmission mount and bracket from the transmission. Refer to Transmission Rear Mount Replacement .
Installation Procedure
Install the rear transmission mount to the transmission. Refer to Transmission Rear Mount Replacement .
Install the front transmission mount to the transmission. Refer to Transmission Front Mount Replacement .
Use a transmission jack to position the transmission to the vehicle.
Notice: Refer to Fastener Notice in Cautions and Notices.
Important: The number 3 position does not require a bolt.
Secure the transmission to the engine.
Tighten
Tighten the bolts to 75 Nˇm (55 lb ft).
Connect the vehicle speed sensor (2).
Connect the backup lamp switch harness connector (1).
Connect the shift cable to the transmission. Refer to Shift Cable Replacement .
Install the starter. Refer to Starter Motor Replacement .
Connect the drive axles to the transmission. Refer to Wheel Drive Shaft Replacement .
Lower the vehicle.
Use the engine support fixture in order to raise the powertrain assembly.
Install the transmission side mount. Refer to Transmission Mount Replacement - Left Side .
Position the underhood junction block to the original position.
Install the surge tank inlet hose to the surge tank.
Install the front wiring harness to the junction block bracket.
Connect the positive battery cables to the junction block bracket (1).
Install the positive battery post to the junction block bracket (2).
Install the junction block bracket, bolt (3) and nuts (1,2).
Tighten
• Tighten the nuts to 10 Nˇm (89 lb in).
• Tighten the bolt to 25 Nˇm (18 lb ft).
Install the frame. Refer to Frame Replacement .
Remove the engine support fixture.
Install the top engine to transmission bolt.
Tighten
Tighten the bolt to 75 Nˇm (55 lb ft).
Connect the hydraulic clutch hose to the clutch actuator cylinder.
Bleed the clutch hydraulic system. Refer to Hydraulic Clutch Bleeding .
Release the cooling module from the upper body structure.
Connect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection .
Fill the transmission to the proper level. Refer to Transmission Fluid Replacement .
Old 12-03-2006, 08:45 AM
denniss's Avatar
I don't see a bell housing in the manual, it looks like it is part of the transmission. Here is the clutch install procedure. Sorry if this isn't what you need, but I am a body man, not a mechanic and I don't know how to find some of this stuff in Service Information.
Dennis
Document ID# 894546
Clutch Drive Plate and Clutch Driven Plate (M86)
Tools Required
J 43482 Clutch Alignment Arbor
Removal Procedure
Remove the transmission. Refer to Transmission Replacement .
Remove the clutch cover bolts one turn at a time, until spring pressure is relieved.
Remove the clutch cover and the clutch disc.
Align the machined side of the flywheel assembly, with the machined side of the cover.
Install the J 43482 in order to support the clutch cover to the flywheel assembly.
Install the clutch cover to flywheel bolts.
Tighten
Follow the tightening sequence. Tighten the bolts to 24 Nˇm (18 lb ft).
Remove the J 43482 .
Important: Excessive amounts of lubricant on the input shaft splines may contaminate the clutch disc and cause clutch shudder.
Lubricate the inside diameter of the bearing with Saturn P/N 21005995, or equivalent.
Install the transmission. Refer to Transmission Replacement .
Bleed the hydraulic system. Refer to Hydraulic Clutch Bleeding .
Document ID# 894546
Old 12-03-2006, 09:12 AM
LSX RWD S/C conversion
victory_red_SS's Avatar
Wrong, the SS\SC does not have a getrag.
Old 12-03-2006, 09:40 AM
denniss's Avatar
Sorry, I have a 2.4 with automatic.
Here is the MU3
None of this really looks like what 06REDSS/SC is looking for, but maybe it will help. I can't find trans disassembly in SI.
Dennis
Document ID# 1549382
Removal Procedure
Remove the cover from the underhood electrical center.
Release the forward lamp harness retainer from the ABS modulator bracket, or the proportioning valve bracket, to allow the underhood electrical center to be repositioned adequately.
Remove the underhood electrical center bracket from the vehicle and reposition the electrical center (1) to access the bracket . Refer to Underhood Electrical Center or Junction Block Bracket Replacement .
Release the wiring harness (2) retainers (1) above the brake booster, to allow the electrical center to be repositioned adequately.
Disconnect the hydraulic clutch hose (3) from the clutch actuator cylinder (2) and the clutch master cylinder (1).
Disconnect the wiring harness retainer from the transmission stud.
Remove the upper transmission to engine stud and bolt.
Disconnect the drive axle and intermediate shaft from the transmission and secure out of the way. Refer to Wheel Drive Shaft Replacement and Intermediate Drive Shaft Replacement .
Disconnect the shift cables (2) from the transmission. Refer to Shift Control Cable Replacement .
Disconnect the backup lamp switch harness connector.
Lower the vehicle.
Tighten
Connect the backup lamp switch harness connector.
Connect the shift cable to the transmission. Refer to Shift Control Cable Replacement .
Connect the drive axle and intermediate shaft to the transmission. Refer to Wheel Drive Shaft Replacement and Intermediate Drive Shaft Replacement .
Lower the vehicle.
Install the left transmission mount. Refer to Transmission Mount Replacement - Left Side .
Tighten
Install the top engine to transmission stud.
Tighten
Tighten the stud to 75 Nˇm (55 lb ft).
Connect the wiring harness retainer to the transmission stud (1).
Connect the hydraulic clutch hose (3) to the clutch actuator cylinder (2).
Install the underhood electrical center bracket to the vehicle and install the electrical center (1) into position on the bracket . Refer to Underhood Electrical Center or Junction Block Bracket Replacement .
Secure the forward lamp harness retainer to the ABS modulator bracket, or the proportioning valve bracket .
Connect the electrical connector to the brake fluid level sensor, then press forward on the connector position assurance (CPA) tab of the connector to secure.
Install the cover to the underhood electrical center.
Document ID# 1504133
Clutch Drive Plate and Clutch Driven Plate (MU3)
Tools Required
Removal Procedure
Install the clutch disc and the clutch cover.
Hand start the clutch cover to flywheel bolts, leaving the clutch cover loose enough to reposition for alignment.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Tighten the clutch cover to flywheel bolts in the sequence shown.
Tighten
Tighten the bolts to 30 Nˇm (22 lb ft).
Recheck each bolt torque using the tightening sequence.
Old 12-03-2006, 11:06 AM
06REDSS/SC's Avatar
Dennis
Me too, rebuilding a total that had a cracked bellhousing where it mounts up front to the engine cradle.
Old 12-04-2006, 12:05 PM
06REDSS/SC's Avatar
so, i found out that the trans has to be completely disassembled, meaning all the gears and everything just to change the damn bellhousing.
05-28-2022 03:47 AM
Turbo Johnny
02-21-2019 09:41 AM
01-12-2016 12:01 AM
09-27-2015 08:53 PM
DevZX
09-16-2015 06:19 PM
Quick Reply: Splitting Trans from Bellhousing
