Stock clutch tq capacity
Old Jul 12, 2008 | 03:34 PM
kenhebe's Avatar
Does anybody know what the torque capacity of the stock clutch is? Do I really need to get an upgraded clutch with the mods in my sig or will the stocker be just fine to throw back in there.
Old Jul 12, 2008 | 03:43 PM
BLAZIN07SS's Avatar
I'm too JDM for you
if your changing the clutch out already, you might as well put in an aftermarket one.
Old Jul 12, 2008 | 03:49 PM
kenhebe's Avatar
I just don't want to buy into the hype that an aftermarket clutch is better and spend a ton of money. I did that on my header and it kicked my ass. I was just curious as to what the torque capacity of the stock clutch is so I can decide what I want to do.
Old Jul 12, 2008 | 06:02 PM
ralliartist's Avatar
With your mods, you will be perfectly fine. I would say that you shouldn't have to worry about upgrading your clutch unless you are bolting on a turbo or the tvs and going for big power. As long as you are on the stock blower, your fine.
Old Jul 12, 2008 | 06:07 PM
steddy2112's Avatar
Paul put down close to 400 wtq didn't he?
Old Jul 12, 2008 | 07:24 PM
kenhebe's Avatar
Anybody else?
Old Jul 13, 2008 | 11:21 AM
Sufu's Avatar
if your already changing your clutch, and not putting in a better aftermarket one then your just wasting your time and money.
Old Jul 13, 2008 | 05:44 PM
miked5426's Avatar
i got 83,000 miles on my fact clutch. never had a problem wit it yet.
Old Jul 13, 2008 | 05:48 PM
an0malous's Avatar
all depends on what your doing with it.
the stock clutch is far more capable than some people would lead you to believe.
but it is very unforgiving on people who abuse it.
I personally have somewhere around 200 track passes on my car,
with somewhere around 270 hp, slicks, and that much track racing, mine has started to slip a tiny bit on the 1/4 mile.
but on street tires it still chirps second with a powershift
Ill be replacing mine with an exedy in a few days here,
but only because I want more grab on the track, not because the clutch is bad
Old Jul 13, 2008 | 05:55 PM
JimzSS's Avatar
GM warrantied mine at 7000 miles because it wouldnt grabe well under hard driving conditions. I am not a rookie at stick shifts. I took a runner up position, in a 5.0 stang 5sp, for a seasons points back when. The service manager agreed that the friction material was holding fine, but the holding pressure wasnt the best. I dont know tourque #s...but replace it with aftermarket if you have it apart. IMO
Old Jul 13, 2008 | 06:23 PM
firemanfrank's Avatar
You ask a good question. But unfortunately, on this forum 1/2 the people are gonna say the stock clutch is fine, the other 1/2 are going to say it sucks.
Whether you ask "experienced drivers" or "inexperienced drivers", whether they are "racing" or "not racing" ... "blah, blah, blah".
The response will still be the same, 50/50. Trust me.
I had a bad slave cylinder on my car at 5k, and the dealer replaced the entire thing under warranty (flywheel, pressure plate, disc, slave). In the mean time, I had wasted many months asking people here about clutches when I just should have gone to the dealer.
So do yourself a favor and completely ignore the "is it good or bad argument", and use this rule of thumb:
  • If it's not slipping, don't replace it
  • If it's slipping and it's still under warranty, see if the dealer replace it with the OEM clutch
  • If it's slipping and it's out of warranty, replace it with a better one
That's all you need to know.
Last edited by firemanfrank; Jul 13, 2008 at 06:24 PM. Reason: Automerged Doublepost
Old Jul 13, 2008 | 08:25 PM
an0malous's Avatar
more like 85/15....but whos counting
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
