Throwout Bearing/Slave Cylinder?
My car has been making some funny noises latley, i'm thinking its my throw out bearing. No noises at idle, if i'm cruising at speed, but not on the gas (or clutch) there is a slight clunking noise, and if i depress the clutch it is at it's loudest. I'm thinking its my throwout bearing, does anyone have any input?
http://www.youtube.com/watch?v=EFic7mA4gr4
someone had mentioned it sounded like a rod slapping around in the cylinder hole.. i hope this isnt the case. i'm still praying its the throwout
Okay, everything is fixed.
I thought I'd check out my front suspension just for laughs and it turns out it wasnt my trans at all. Upon looking at the front left tire, I noticed that one of the wheel studs had sheared in half. Because of that, the other bolts loosened up causing the wheel to shake and make the noise. Surprisingly enough, I felt NO vibration in the steering wheel.
Im glad it wasnt anything too serious, but after driving 70 miles with the wheel like that I'm lucky nothing bad happened.
yeah u are very lucky, two nights ago y buddies wheel studs sheared off and his whole wheel fell off of his car, he had just finihed doing bumper work and fender works and the bumper got ripped off and his fender was all bent to hell, good ole bonnevilles
09-28-2015 12:51 PM
Getaway_Driver
09-08-2015 09:41 AM
