traction control on non abs car
Old Apr 28, 2015 | 03:06 PM
Crav3's Avatar
I have a 2009 Pontiac g5, the car came without abs and I paid that no mind when I got the car. I live in Texas and having traction control was not an issue to me since I never really snows here. I decided to supercharge my car just to have a little power under the hood. I noticed after the tune that after too much wheel spin the engine cuts off and I cannot accelerate. I talked to the guys at trifecta and they say its traction control. This is obviously affecting my runs at the 1/4 since I cannot launch the car properly. The trifecta guys told me to try launching in l or with the parking brake one click up, but unfortunately it still cuts my engine off. Does anyone know anything I can do to get rid of this annoying "traction control"? I was going to get drag radials or slicks but cannot do a burn out to heat them up, so it would be a waste of money. Have any of you had this problem? If so how can I solve it?
I have an auto transmission BTW.
Old Apr 28, 2015 | 04:06 PM
breds2k's Avatar
Trifecta is asleep at the wheel, I had a 2007 and the only way to remove what GM calls "Torque Limiting" is to tune it out.
Althought 2009 may be different as far as another way to remove it, it was literally the most annoying thing ever. If you pedal it sometimes you can get through it but your screwed at the track.
Old Apr 28, 2015 | 04:30 PM
Crav3's Avatar
Yea that is what I thought and I told them to tune it out and they gave me some vs about it being a safety issue and then changed it on me that its part of the BCM which I doubt because I heard some guys tuned it out with hptuners. But thanks I'll ask someone I know and see what they tell me
Old Apr 28, 2015 | 05:58 PM
breds2k's Avatar
makes, sense I had heard before that trifecta couldn't remove it. I had it removed from my sedan via hpt. You need to in the snow its literally dangerous to pull out of a street in the snow and then all of a sudden have no acceleration because your tires spun for an 1/8 of a second and the computer kills throttle.
Old Apr 28, 2015 | 08:27 PM
Crav3's Avatar
Yea I think I'll have to have someone check if the 09 is the same. Hopefully it is, if not I think I'll be getting rid of the car if I can't have fun with it lol
Old Apr 29, 2015 | 02:30 PM
bland1's Avatar
When I rented a g5 years ago I noticed it would shift into second right away if the revs got to high or it was spinning to much. Trick was to feather the throttle just right so it doesn't shift early.
Also the revs were limited when flooring it in neutral. Trick was to hold the gas and brake and keep dipping the transmission between N and D to get it to rev higher. I love rental cars.
Old Apr 30, 2015 | 07:08 PM
BLKLS's Avatar
How do you have traction control with out abs? I thought they where the same system?
Old May 1, 2015 | 02:36 AM
Crav3's Avatar
Well I have pedaled it to avoid it but I lose a lot of time, and at the race track I will mistakenly give it too much gas and spin the tires too much, takes like half a second.
I don't have abs so gm, being the smart company it is, decides to implement a different way to control wheel spin. It just totally cuts your engine off and have no power for about a second or two before you canaaccelerate again. Kinda hard to explain maybe I should record a video for every to see.
tomj77
Oct 2, 2020 05:36 PM
Meadowvalien
Aug 17, 2017 06:32 PM
chefhhr
Oct 26, 2015 10:36 PM
Turbo6
Sep 24, 2015 04:15 PM
jthwjde
Sep 7, 2015 09:24 AM
