tranny or bearing?
a release bearing will usually make a noise when the clutch is pressed as there is more load on it. when you release the clutch pedal in neutral the input shaft turns. usually a noise as described is caused by a bearing on the input shaft coming apart.
I'm dealing with one right now....I just Installed a brand new clutch AND TOB and my TOB is Faulty, Watch because GM has a BUNCH of Faulty LNF TOB's out there, I believe ZZP dosent even stock them anymore cause theres soooo many Bad ones.
Iceberg
Sep 29, 2015 12:33 PM
