Tranny mount quick fix
I have seen the thread on here before(and just got done searching forever)...i would like a link or someone to tell me what you use fill in the rubber part of the mount with.
I know you have ot let it cure for a while, and now that its nice out...I can do that...any help would be sweeeeeet thanks ahead of time
Be careful man. It takes at least 24 hours before you can start your engine after putting the mounts back on. I let mine dry overnight (which I thought was long enough) and when I checked them the next day, most of the polyurethane had oozed out.
Also, not sure about your driving habits or preference, but I ended up taking mine out because I couldn't handle the vibrations. I very rarely race, if ever, so it didn't seem worth it to me. This mod was a lot more rough then I expected it would be, based on everyone's comments in that thread. The worst was easing out in reverse, and low rpm shudders right after startup. It did eliminate wheel hop and make hard shifts smoother though. Good luck.
