Tranny mount UPGRADE
Old Nov 17, 2005 | 02:05 AM
Chevypowered's Avatar
Well last weekend I ordered a tranny mount from RSM racing for my SS. I called today
because I hadn't heard anything and got some great news. They are now reintroducing their
billet aluminum mounts and I'll be the first to get one . I expect this part to greatly
reduce wheel hop and I may get some vibrations but it shouldn't be too bad. This might be a
great alternative to the goofyguy/weapon R selection we have now, plus it will look
nice. it was $250 and I believe there is a core refund if you'd like to send your stock back into
them but with the new mount I’m not sure if it true or not. I get it Friday and will have it
installed Saturday. They make these for the three tranny types so theres some for all.
Old Nov 17, 2005 | 03:41 PM
R33P3R007's Avatar
360 L337 User
got a Link?
Old Nov 17, 2005 | 07:23 PM
mugencivicsi's Avatar
Saturn Ion Transmission Mount
Part Number: TM1GA22F-0406
$160 plus $60 Core charge
Z-Spec Polyurethane & Billet Lower Engine Mount
Prevents engine movement and recovers up to
10 ft/lbs of torque.
$64
is that the mounts you are tlaking about.. is it not for the Saturn Ion Redline (or is it a universal peice) if so i have been waiting on these to order them
Old Nov 17, 2005 | 08:59 PM
Here is the site RSM Go to catalog and look under ion. They have 3 different types of mounts depending on if ou have a SS S/C manual, 2.2
Manual, or the automatic. When you send in you order they will contact you to find out what kind you need. The pic they have on their page is an old style, I will put some pics of the new
style when i get it. Its the first of the two that you have. i used to be 220 but i think with the new part is 250.
Old Nov 17, 2005 | 09:10 PM
wikkymaster's Avatar
i know the j-body community has a lot of problems with RSM, they take forever to ship products and customer service sucks
Old Nov 17, 2005 | 09:11 PM
I ordered mine yesturday it shipped today and will be here tomorrow
Old Nov 18, 2005 | 08:08 AM
distillion's Avatar
luckily for me they are 30 mins away, they are good its that other company they deal with that sux i cant remember wat the name is now, but rsm is a good company and they do know there stuff.
Old Nov 18, 2005 | 08:03 PM
Ok i recieved it, i got some pictures They will be up in a sec
Old Nov 18, 2005 | 08:09 PM
This might work^^^^
Old Nov 18, 2005 | 08:11 PM
And heres a pic of my car and my bros Jetta GLI Stage II
Old Nov 18, 2005 | 10:06 PM
So i was impatient and i installed it tonight. First off and most importantly the wheel hop is
virtually eliminated except for a tiny bit if you're going all out from first to second. Now this
might not be for someone who doesn't like vibrations. At idle the virbrations are at the worst
and when first reving up. There is more road noise and exhuast noise but just turn the music
up. Here are some pics, the install was a breeze, i would compare it to the strut tower brace,
which i did this morning. Pics VVV
Before:
After:
Old Nov 18, 2005 | 10:36 PM
max_boost's Avatar
That looks like a nice piece, I might have to get one of those.
Old Nov 18, 2005 | 10:48 PM
As long as you aren't worried about vibrations then it is a good upgrade
Old Nov 19, 2005 | 01:25 PM
cvenom2122's Avatar
Thumbs up
can you please show me a far pic of were that goes is that on top or under the car? do i need a tranny stand to support it while i install it?
Old Nov 19, 2005 | 09:01 PM
Its under the car this shows you where it is.
I did use a jack to hold it up to be safe, i wasn't sure if i needed it or not but i would rather no need it then not use it and damage something
Old Nov 20, 2005 | 10:03 AM
geedog66's Avatar
so how does is handle??
Old Nov 20, 2005 | 10:09 AM
There is definitely more vibrations when at low RPMs and when starting off. Then at higher RPM there is an exhaust resonance if the windows are up. I don't know if i am going to keep it on all the time or only when I go for a race. It takes about 30 min to swap it out. With it on the response is definitely quicker; don't really have very much bog down like I did, so it does its job.
Old Nov 20, 2005 | 08:12 PM
97cavie24ls's Avatar
is it just the front mount and no rear mount ??
pretty nice looking piece
Old Nov 20, 2005 | 08:21 PM
Just a front, if you had both you might as well weld the engine to the frame
Old Nov 22, 2005 | 09:13 AM
geedog66's Avatar
any wheel hop with it???
Old Nov 22, 2005 | 09:36 AM
R33P3R007's Avatar
360 L337 User
read his post... ^^^^
Old Nov 22, 2005 | 04:06 PM
astrocrep's Avatar
I got a couple of quick questions for you.
How would you compare this against an engine tourqe brace?
And do you still get wheel hop with it on? You don't specifically mention that so I wasn't sure.
Did you keep it on?
Thanks
Rich
Old Nov 22, 2005 | 04:20 PM
R33P3R007's Avatar
360 L337 User
Originally Posted by Chevypowered
So i was impatient and i installed it tonight. ]First off and most importantly the wheel hop is
virtually eliminated except for a tiny bit if you're going all out from first to second. [/B]
Now this
Before:
After:
Read This ^^^
Old Nov 23, 2005 | 08:44 AM
littless's Avatar
I just did this same thing yesterday but, i did not pay 130 dollars or what ever the cost was. i paid 22.50. i did not want all the vibrations from solid mount like what you are getting so i took my mount out cut all the rubber out and use 80 shore poly urethane and filled it back up. i get a little vibration at idle but hey you have to take the good with the bad. this is by far the best mod that is available! i also have the goofy guy brace as well and with these two on i have not wheel hop.
damn you got to love the forums!!!!!
Old Nov 23, 2005 | 08:54 AM
Did you keep it on?
Thanks
Rich
The nice thing about this piece is instead of trying to support the engine from somewhere that isn't designed to support, the solid mount is supporting it where it is designed to. I was considering the torque braces but after looking at where it mounts i wasn't satisfied. I recently had a ride in a ss s/c that was stock and i had forgotten about the loud hammer sound it makes when shifting into second hard. Mine does that no more.
I did get some wheel hop the other night, i was showing off and lighting up the tires through first for a good 10 secs and finally right at the end i got a little wheel hop but not bad. I had raced a few times and no wheel hop was experienced. So i think unless its your showing off you won't get wheel hop.
I am keeping it on. It really isn't that bad. I have a truck with a V-8 in it tat is pretty loud and has a little vibration so it doesn't bother me. If i had to drive family around or someone like that i might not keep it in, but that would be the only reason.
