tranny shim
Old Sep 16, 2010 | 10:32 PM
advise's Avatar
tranny shim
is the tranny shim 100% necessary i forgot to put it in
Old Sep 16, 2010 | 10:35 PM
boost_junkie16's Avatar
I would assume so. It must be there for a good reason.
Old Sep 16, 2010 | 10:37 PM
advise's Avatar
i kno that but whats the deal without it im doing my clutch as we speak and im almost done
Old Sep 16, 2010 | 10:38 PM
lsjion's Avatar
yes it's very important.......in you want your starter to live
Old Sep 16, 2010 | 10:39 PM
advise's Avatar
it doesnt shim the starter....
Old Sep 16, 2010 | 10:41 PM
Dayta's Avatar
Yes you need it!!!!!
Old Sep 16, 2010 | 10:42 PM
elite_Cyborg's Avatar
Well, your throwout bearing is now gonna be alot closer to the pressure plate, as is everything else
Old Sep 16, 2010 | 10:43 PM
Dart_SI's Avatar
if you take apart your tranny and put it back together again... and have spare parts... your doin it wrong.
advise's Avatar
any idea on getting it in without pulling the tranny fully
Old Sep 16, 2010 | 10:44 PM
Dayta's Avatar
you need to fully pull it back out. trust me, i went threw this before
Old Sep 16, 2010 | 10:46 PM
advise's Avatar
**** im almost done i got the fuse box almost in
what will happen if i dont lol
Old Sep 16, 2010 | 10:54 PM
unbolt your tranny mounts, bellhousing bolts and pull your axles out then just slide the transmission sideways. You'll be able to get the shim in. I did my entire clutch job without taking the transmission out.
Old Sep 16, 2010 | 10:56 PM
advise's Avatar
ima update you wit how it goes without the shim
Old Sep 16, 2010 | 10:58 PM
that could/probably will be an expensive lesson to learn.
Old Sep 16, 2010 | 11:00 PM
advise's Avatar
ive done countless trannys on mustangs with no problem without the shim
Old Sep 16, 2010 | 11:08 PM
thedubsack85's Avatar
when did you trade the balt for a mustang? you need that shim.. like stated above you can get it back in without pulling entire tranny.. will take alittle finesse i guess.. good luck!
Old Sep 16, 2010 | 11:20 PM
lsjion's Avatar
nevermind, I'm thinking about how honda starters are mounted, but still, it's needed
Old Sep 16, 2010 | 11:22 PM
advise's Avatar
ya it is the intermediate shaft wnt bolt up
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
zdohare
Sep 23, 2015 11:31 AM
