Trans bearing failure...
Old Oct 5, 2013 | 01:27 AM
calicobaltSS's Avatar
Well as the title says...my tranny has a bearing that's failing...it's either an output bearing or a bearing on the main shaft...noise is coming from front if trans near the end plate on drivers side....I'm also @ 110 k...so I'm guessing GM won't cover it...
Old Oct 5, 2013 | 08:38 AM
Wouldnt be too hard to replace if you knew what you were doing, just a lot of labor dropping the trans. Let me know if you need any help, i have access to alldata and mitchell.
Old Oct 5, 2013 | 03:30 PM
Thanks bro...I'm actually a mechanic myself...I've replaced the clutch before so yeah it sucks...I'm debating on either rebuilding it or just getting one and installing it...also debating on an LSD add since I'm a non G 85 LSJ��
bigdeertz
Nov 17, 2016 09:41 AM
HEATON
Oct 16, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
OPCrer
Sep 27, 2015 08:11 PM
