Trans Blows Agen!!!!!!
well guys as some might remeber my car was in the shop for a little over a month to get the trans fixed when it ended up being a roll pin...well i got the car back a little less than 2 weeks ago and guess what it did today! it ****** broke agen.....not even driveing hard about to down shift and go in to a parking lot....i cont even begin to say how pissed and unhappy i am with that car rite now.....this has never happend to me before on any of my other cars!!
Sounds like maybe someone didn't finish the job the first time. I've only had one problem with mine and that was the linkage cable was tensioned too tightly (others had the same problem and the cable will eventually snap). Service manager adjusted it for me and now it's perfect. I even got complements from some Honda guys about the smoothness in the shifter (which says a LOT for it, since Hondas tend to have very smooth shifters).
i've called in my contacts and delt with the dealer....there going to do a little custom work on that specific pice on my car and they better hope it works out or they are going to have one very pissed of guy in there servis shop
Originally Posted by 05_Blue_B10WN_SS
How can you tell id your linkage is too tight? Is it normal for you to have to apply more force to get it to go in first gear (at a dead stop) then any of the other gears?
Originally Posted by TimDang
my first is a bitch to get into sometimes, sometimes wont go in at all untill i clutch, neutral, clutch, then first.
Hopefully they take care of your tranny problems, what a huge pain in the ass to say the least.
At any rate, first should be hard to get into, but when you're stopped go to 2nd and then 1st. EVERYONE I know shifts a manual like that and it'll go in smooth as can be. Your linkage is too tight if you CONSISTANTLY have problems with the other gears during normal (NOT hard) shifting. My problems were with 2nd and sometimes 4th. I'd go to shift and there would be a brick wall there or I'd get it in and it would pop back out. Took it to the service manager, talked to him, he went out in the parking lot and got in there and loosened the cable just a little bit and *poof* no more problems. Occasional problems aren't anything to worry about, if it's doing it all the time then there's a problem.
SHES BACK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
got her this morning and now shes sporting new spark plugs/new billet flow 2.9 pully/new windsheld!!!
i love her once agen...they dubbled up the roll pin this time...we'll see how she works this time
Originally Posted by max_boost
How does that pulley feel? I wanted to wait until spring to install mine (3.15) but it's getting hard.
its amazeing!!!! but i get some belt squeel and i dont know how to stop it.
it pulls soooo hard now i hit 80 now like the car hit 60 before...do it now and hope you clutch survives!
