Trans diagram?
Trans diagram?
Anyone know where I an get a diagram or a LSJ trans mainly where the bolts bolt up? Putting my trans in tomorrow but it's been 3 weeks since I had it out so I dont wanna misplace any bolts when putting it back in.
Thanks guys.
Thanks guys.
to bolt trans to motor, make sure you put the spacer in, i use grease to hold it in place.
as you look at the trans from the passenger side wheel.
two bolts at the bottom. two bolts on the left side (exhaust side) above the rear mount bracket.
On the inlet side, one bolt above the starter motor.
as you look at the trans from the drivers side wheel.
one bolt at the top by the clutch distribution block, has a built in stud to hold a wiring harness clip.
one bolt above the front motor mount bolts.
thats all i can remember lol
the bolts are 18 mm socket head, only one is a stud. u need a deep 18 mm socket for that.
but be cautious, and line up the bolts ahead of time. they are around 60 mm long iirc..
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
