Trans swap w/ goodies attached.
Old Oct 6, 2012 | 12:12 AM
Nfamous60's Avatar
Hey everyone recently found out that the lsj trannys are better then the LNF so a gud friend of mines from bac at fort bliss is willing to swap trannys with me he has more miles on his but its still in gud condition ( we always drive together/ no homo) i figured it would be a gud chance to get a better tranny and drop in my Spec clutch n flywheel. I am also giving him my entire stock turbo setup everything included with IC piping for free. since i have ZZP IC piping, what do you guys think?
AWWW **** JUST REMEMBERED AFTER POSTING THIS: ISNT THE BOLT PATTERN ON THE LSJ N LNF DIFFERENT MY CLUTCH N FLYWHEEL WONT MATCH UP...smh
Old Oct 6, 2012 | 12:17 AM
Fitz88's Avatar
i was always told the lnf tranny was better
Old Oct 6, 2012 | 12:24 AM
carstedt's Avatar
lsj trans is better since it has the 4.05 wher as the lnf has 3.82 IIRC
Old Oct 6, 2012 | 01:50 AM
Nfamous60's Avatar
yes found that out few days ago..
Old Oct 6, 2012 | 05:16 AM
too gud to be true?
Old Oct 6, 2012 | 09:38 AM
Nfamous60's Avatar
^^^wut the tranny swap or goodies?
Old Oct 6, 2012 | 09:42 AM
FrossB's Avatar
Thread Killer
too gud to be true?
Old Oct 6, 2012 | 09:49 AM
turbosmart4's Avatar
Not sure if serious lol
Old Oct 6, 2012 | 09:57 AM
FrossB's Avatar
Thread Killer
So you gave him 700+ dollars in parts for free for swapping your guy's trannies? Is that what i got outta this?
ps, i would highly suggest you have that LSJ tranny rebuilt since it is high miles. It is "stronger" that the LNF tranny but not by much. And when i say "stronger"...i mean it is the same metals and still has the same breaking strength...but due to the slightly shorter gears it is LESS LIKELY to break
Old Oct 6, 2012 | 01:05 PM
Nfamous60's Avatar
im not goin to use my stock turbo or any of those parts after i swap out im not money hungry or anything and he is by far a very gud friend he has a lsj he wants to turbocharge but just had a son so his build will be slow, least i can do is help by giving him parts i kno i wont use. his goal is only 350-400 so i asked bout the tranny, he said it would be fine so i made the thread. but realized after posting it my Spec clutch n fly wont fit.
BUT main question is will my Spec clutch n fly i brought for my LNF tranny fit on LSJ tranny?
FrossB's Avatar
Thread Killer
Well thats nice of you man
Old Oct 6, 2012 | 01:10 PM
Nfamous60's Avatar
yes to gud to be true but very much fine on my part since i brought Shultz ZZP piping with maf relocate so dont need lower charge pipe brought his upper so dont need mine, buyin treadstone!! downpipe n intake becuz of the combined deal so dont need my intake, of course i could sell it on here but I have a friend in need so i have no problem helping out.. plus remember my car was brought with all hahn fbo's so its not really a lost for me. LMAO dont everyone wish they had a friend like me lol......serious though dont you wish?
Old Oct 6, 2012 | 01:33 PM
bluebalt07's Avatar
Flywheel and clutch don't bolt to the tranny so they should be fine. Besides, the LNF and LSJ use the same bolt pattern on both, from what I understand the LNF just has a heavier flywheel and stronger clutch
Old Oct 6, 2012 | 01:37 PM
Dart_SI's Avatar
i like the 4.05 final drive of the lsj trans. Although if the stock trans could hold taller gears are better on the highway.
Old Oct 6, 2012 | 01:49 PM
Nfamous60's Avatar
ok but since im using aftermarket clutch and flywheel i should be gud. like previously stated i will get it rebuilt.
Old Oct 8, 2012 | 12:52 AM
06SS ALL DAY's Avatar
Gud or god? My iPhone makes gud into HUD. What's this dood sayingż
Old Oct 10, 2012 | 08:49 PM
rwperlaki's Avatar
Bolt pattern on the trans is the same and clutch splines are the same so your good to swapp
Old Oct 10, 2012 | 09:22 PM
Powell Race Parts's Avatar
where is this going? LSJ/LNF flywheels and clutches, TOB, trans casing, gears, are the same fitment, bolt pattern forward and backwards compatible, other than material in the clutch face, the final drive ratio, the TOB is different spec but fits the same and is an upgrade, the shift lever is shorter on the trans side, and the shift cable bracket on the trans is solid mount.
the rest is popcorn. someone said the LSJ would have higher miles, they are right. short gears dont make the trans stronger, they do shift the torque /speed/gear relationship some.
Old Oct 11, 2012 | 01:07 AM
Nfamous60's Avatar
ok thank you...
Old Oct 14, 2012 | 08:06 PM
mongorat427's Avatar
Here we go again John
Old Oct 15, 2012 | 12:40 AM
gmlifestyle's Avatar
I'm doing this as well .... The lsj tranny swap I mean....so what won't work.....shifter cables? Shift linkage? Tob?clutch?...I have stock flywheel and clutchmaster stage 4 ....I just blew my f35 can use some good advice....be thorough please and elaborate thanks
Old Oct 15, 2012 | 07:25 AM
Try to find a trans with low miles on it. There is no way to really tell if they have been abused but you can move the input shaft around and see if theres any play. Check the fluid for color if theres any left in the trans and remove the drain and fill plugs and see if there is any metal on them.
Old Oct 15, 2012 | 08:03 AM
Joe Schulte's Avatar
My HHR/LNF is 4.05, but it still self destructed third gear, so eh! Also toting around 400 extra lbs in sheetmetal/glass too though.
Old Oct 16, 2012 | 02:35 AM
Nfamous60's Avatar
^^^^wow
Old Oct 16, 2012 | 07:42 AM
My post # 18 was thorough. applies to all cobalts. 2004 saturn ion redlines; the LSJ trans wont work in a cobalt as the bellhousing is not machined for a vss off the cw gear. 2004 Redlines are however backwards compatible for trans.
