Transmission to Axle Part
Old Aug 1, 2016 | 01:15 PM
Elfresh's Avatar
In the Image below what is that thing called?
anyone know that part Number?
How do i remove it to put it into a new axle?
Old Aug 1, 2016 | 01:26 PM
JapEatr's Avatar
South Central *********
try a prybar, or sometimes I use an air hammer
Old Aug 1, 2016 | 01:32 PM
Elfresh's Avatar
Thank you
I May have messed the rubber not sure yet
do i need to disassemble the ball joint to push it out with an air hammer
any other tips?
Old Aug 1, 2016 | 01:41 PM
JapEatr's Avatar
Remove brake caliper, remove rotor
Remove two 18mm nuts at the knuckle to strut connection
this will pivot the knuckle out so the axles spline can be removed from the hub
now that the axle is only held in by the trans, pry at the transmission to "POP" it out of the diff.
Old Aug 1, 2016 | 06:02 PM
the part youre looking at is all one piece with the axle. You can only order the whole thing
Old Aug 1, 2016 | 06:29 PM
Sharkey's Avatar
actually, if he has an auto the part he circled is seperate. the 4t45e uses a male-male spline stub shaft, and the inner axle cup has female splines.
Old Aug 1, 2016 | 09:54 PM
Doh. I always default to manual. Carry on.
biniecki
Sep 18, 2016 02:42 PM
Kwin
Jul 27, 2016 05:32 PM
mrader88
Jul 26, 2016 03:22 PM
heinen02
Jul 19, 2016 03:03 PM
Studer
Jul 7, 2016 10:27 PM
