Transmission Failures/Problems 2.2/2.4/2.0
Old May 3, 2008 | 04:15 PM
Cobalt(312)'s Avatar
I'm trying to get a thread together so that everyone can discuss how their trans has failed on them at one point, so for those people who would still like their warranty to cover it, it does. maybe using this we may be able to figure out what part is actually causing it the most.
2ND GEAR GRINDS WHEN LET CLUTCH OUT
SECOND GEAR TEETH CHAFFED BAD SYNCHRO ASSMY TEETH SHEARED OFF & 1ST GEAR
ROAD TESTED SEVERAL MILES---TO DUPLICAITE-R&R TRANSMISSION
TO INSPECT---REPLACED 1ST & 2ND GEARS & SYNCHRONIZER ASSMY
REPLACED BLOCKER RINGS & BEARINGS--ALSO HAD TO CHIZZEL
BROKEN INTERMEDIATE SHAFT NEEDLE BEARING OUT WAS COCKED & STUCK IN CASE HALF-- REPLACED THE SHIFTER ASSY ON TRANS.
REFILLED & ROAD TESTED ALL OKAY THIS TIME----OLH--2.OHR---TO REMOVE BEARING CAGE & ROAD TESTING ETC.
The repair had to be authorized by a GM service manager, and they wouldn't take my car in the first day i brought it there and it was doing it i had to come back 6 times more till they took it and gave me a rental.
Last edited by Cobalt(312); May 3, 2008 at 04:15 PM. Reason: Automerged Doublepost
Old May 3, 2008 | 04:31 PM
Mr_Slobalt's Avatar
over 15k and no problems...not even a grind
Old May 3, 2008 | 04:34 PM
wisemanonice's Avatar
almost 30k. so far so good...
Old May 3, 2008 | 04:43 PM
mkulrey13's Avatar
62k miles works like a charm. New clutch for my power tho.
Old May 3, 2008 | 08:00 PM
yeah mine started killing me at 20k
Old May 3, 2008 | 08:08 PM
DaREDss's Avatar
destroyed the roll pin in my linkage only had 4th gear it was replaced under warranty even though they siad the only way i could break it was with heavy shifting...
Old May 4, 2008 | 08:24 AM
firemanfrank's Avatar
8.5k with no problems ...
Old May 4, 2008 | 08:39 AM
powerz's Avatar
bought it with about 18,000 miles .had a warped flywheel at 23,000 .so they replaced fly wheel and clutch i paid 272$ to upgrade clutch . 72,000 now and no problems so far
Old May 4, 2008 | 02:54 PM
Old May 4, 2008 | 02:57 PM
Smarty Art's Avatar
15,500 miles and no problem with the tranny or clutch.
Old May 4, 2008 | 07:29 PM
Old May 4, 2008 | 10:02 PM
CARLOS's Avatar
mine gave up at 35000 miles. coming home from work went to 3rd gear and then try to go back to second bacause of traffic and car would not gear at all
Old May 4, 2008 | 10:03 PM
Cobalt_SSTuner's Avatar
50k miles... no porblems yet!!1 knock on wood!
Old May 4, 2008 | 10:14 PM
Asphalt Assault's Avatar
I had a partial failure on my F35
would pop out of second after making the shift and engaging clutch, then just pops out part way almost to neutral without accelerating or depressing accelerator.
so long story short - unrepairable with ease so they put in a new one. No real explaination as to why. was done for 4 wks with a rental.
Old May 4, 2008 | 10:20 PM
FASTL61's Avatar
i have a grind in second only at high rpm.what the hell is that i have 18k miles....warranty???
Old May 5, 2008 | 12:52 AM
OHHH grind eh. speed shift much?
Old May 5, 2008 | 02:09 AM
FASTL61's Avatar
lol wow you know me oh so well....the force is strong with you!lol.will they cover it under warranty?
Old May 5, 2008 | 01:38 PM
it's warranty covered, i saw in another thread u were thinking about changing your trans fluid if you do they'll void it but if you got and 07 is 100,000 is its mechanical. and since your under 36,000 it should all be covered.
Old May 5, 2008 | 01:41 PM
steddy2112's Avatar
Third gear effin hates me.
Never grinds, but going 5th to 3rd to pass make f23 unhappy.
More double clutching is in order...
Old May 5, 2008 | 01:44 PM
just get a hold of your dealership ASAP and get it in the longer you drive on it the more it looks like abuse and they may deny you. And once you get it back when shifting between gears they'll be some force on your shifter when engaging the next gear wait until it allows you to slide it in easier because when it pushes the synchros have not yet lined up and thats why shifting hard destroys these transmissions. It pushes the tabs on the blocker ring down further when you power shift destroying the sychros and causing gear clashing
Thats is terrible for your clutch, and transmission. Going 5th to 3rd means that the flywheel is spinning fast then it would in 4th causing more clutch wear
Last edited by Cobalt(312); May 5, 2008 at 01:45 PM. Reason: Automerged Doublepost
Old May 5, 2008 | 01:47 PM
steddy2112's Avatar
Originally Posted by Cobalt(312)
Thats is terrible for your clutch, and transmission. Going 3rd to 5th means that the flywheel is spinning fast then it would in 4th causing more clutch wear
Yeah but down shifting from 5th to 4th then 4th to 3rd is lame.
I know why it does it... and if you double clutch it, or if you rev match it it makes for a happier tranny.
I know I will be replacing the clutch one day.
That day will be before 40k miles.
Old May 5, 2008 | 01:52 PM
ok was just saying i've been there i'm still using a stock clutch but solely because i'm afraid to mess with the tranny till this thing is paid for. And then all things aside i'm going to buy another transmission install a LSD and fidanza flywheel and upgraded clutch
Old May 5, 2008 | 01:53 PM
steddy2112's Avatar
Ding ding ding.
I will blow this car up at least twice
Old May 5, 2008 | 08:01 PM
YEP, well i plan on making this not my Daily Driver once its paid for
Last edited by Cobalt(312); May 5, 2008 at 08:01 PM. Reason: Automerged Doublepost
Old May 5, 2008 | 08:05 PM
FastSSinNH's Avatar
26k and no problems whatsoever.
