Transmission Failures/Problems 2.2/2.4/2.0
Old May 6, 2008 | 09:58 PM
Cobalt(312)'s Avatar
Old May 7, 2008 | 05:19 AM
T Dawg's Avatar
70,000+/- started giving a rattlish sound when shifting or letting off after a wind up. Haven't looked into it yet. Yeah, I'm mean to her, but she still loves me. :-)
Old May 8, 2008 | 07:49 PM
haha aren't we all, but it is somewhat ridiculous well in my case at least and a few other
Old May 8, 2008 | 07:57 PM
elecblue06's Avatar
clutch master cylinder went.. grinding ... doesn't go in gear.. the later 2 are totally random though lol clutch master cylinder was replaced.. got 40 K on the car and for the most part it's ok
Old May 11, 2008 | 07:35 PM
Old May 11, 2008 | 09:30 PM
BIG-DAVE's Avatar
im going on my third tran's first 1 a gear or something shot through the side dealer repalce that one under warrenty .... second 1. i lost 2nd 3rd and 4th gear im out of my warrenty now so i have to pay for the trans ... geuss they don't hold up to my drivin ...lol has
has anyone had their trans beefed up mad stronger ?
Old May 11, 2008 | 09:49 PM
elecblue06's Avatar
you can take it and get it cryo treated from someplace.. that would help a bit..
there was also a company that was looking at building beefier trans for our cars
Old May 11, 2008 | 10:15 PM
Mr_Slobalt's Avatar
5th gear is getting a bit naughty....we'll see how that works in a month
Old May 16, 2008 | 12:58 PM
BLKSS's Avatar
Cracked my transfer case shifting into 2nd. (wheel hop) Not covered.
34000km
Yes, thats how I roll.
Old Aug 21, 2008 | 09:30 PM
revive
Old Aug 21, 2008 | 09:44 PM
  #36
dsp86's Avatar
Originally Posted by FASTL61
i have a grind in second only at high rpm.what the hell is that i have 18k miles....warranty???
if its not every time and only sometimes its gonna be hard for the tech to duplicate the problem and u will prob have to go back. its hard being flat rate so techs wont put too much time into something cuz they wont get paid when its a warranty job. but id say bring it in any way maybe the will get it to happen and prob start w/ adjust ur linkage.
Old Aug 21, 2008 | 10:14 PM
  #37
elecblue06's Avatar
if it's only at high rpms then they're going to assume you beat on it.. and your tranny warranty goes byebye.. just tell them it grinds every so often under acceleration
Old Sep 3, 2008 | 09:56 AM
  #38
nutsandboldts05's Avatar
Just came across this, BUT, i had a second gear grind going into second from 1st and 3rd at high rpms. They agreed to cover it under warranty but when they got it apart it was bad news for me. they found burn marks on the syncro and the gear was mashed to hell. They still covered it but told me I was shifting at a high rpm and slamming it into gear. Recently I haven't done anything like that. But, a year ago when I first got the car I was doing that stuff. I stopped after a month or two but it was still enough to screw up the tranny. If you are lucky like me they will cover it but warn you not to drive like that.
What I don't get, is why make a tranny red line that high when they aren't meant to be shifted at a high rpm... or amybe its just the speed shifting thats not good for them that caused mine to go bad. Cause there are guys shifting at high rpm's all the time and their tranny is fine.
Old Sep 12, 2008 | 04:50 PM
  #39
Maven's Avatar
To any and all of the guys with 3rd/4th gear prblems......the new blocker rings are now available and a permanent repair(as opposed to the previous short term) can now be made if youve got the grinding 3rd/4th
Old Sep 18, 2008 | 12:29 PM
  #40
Redbird's Avatar
Canada
I had the new 3-4 synchro rings replaced in my '08 LT. No more problems with 3-4. Now 1-2 shifting is very stiff. The dealer is replacing the 1-2 shift fork, detent, and syncros. I should have it back tomorrow. This car has 9000 Km. on it. The dealer says $5800 + taxes to replace it with and indentical '09.
Old Sep 18, 2008 | 12:34 PM
  #41
Staged SS's Avatar
40 tracks runs....... NO PROBLEM
RaginChopsuey
Oct 27, 2015 01:27 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
